Question about Seagate FreeAgent Pro Desktop - 320GB - 7200rpm - 480Mbps USB 2.0, 300Mbps External SATA ... Hard Drive
Seagate external desktop drive
Hi there i can get my seagate to work on my pc but when i plug it in to my usb port on my dvd surround sound it says there no data and i dont get it because i know there is data on it cos i put it on please help.
  • 33 Answers
There seems to be an incompatability. Some of those devices can only read up to a certain file size, like my friend has a digital photoframe that can only recognise up to 2GB. Also try not putting the files in folders and just having them all in the root directory
Posted on Oct 08, 2009
Windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Oct 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
Hi i have an external HD...Seagate FreeAgent GoFlex 1 TB...it is working smoothly on my laptop and other computers..however as soon as i want to connect it to my desktop, it is not being detected. My...
Connect some other USB device (keyboard? mouse? memory-stick?) to your desktop?
Are those devices detected? If not, then either:
* the USB port(s) on your desktop are damaged,
* the device-drivers for the USB ports on your desktop are not installed.
Try connecting it to a different desktop/laptop, to see if the Seagate works at all, on any desktop.
Mar 17, 2011 | Computers & Internet
Need Manual or Instructions for Seagate Portable Hard Drive
Your External Drive should be plug and play enable since it is a USB Drive.
Connect the appropriate cables to the External Drive and from the External Drive to the Computer while the computer is fully booted.
The driver for the Drive is loaded else you will be promted that the system have found a new device, if that is the case, put the CD-ROM that came drive and follow the instruction to complete the driver installation.
Open my computer icon on your desktop and you see the external drive.
Feb 01, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My light is on and a buzz sound is heardwhich stops after a minute and no data is displayed
You do not say whether the HDD ever worked.
If it did, and stopped, chances are that the internal HD is damaged, or the motor performances degraded and it now requiring a higher current than the USB port can deliver.
Try plugging it on a different USB port or, better yet, into an externally powered USB hub. There are also special cables which plug two USB ports into one and deliver double current to the appliance.
As a last resort, it might be possible to recover it by extracting it from its enclosure and connecting to a desktop PC via a 3.5-to-2.5 inch HD adapter.
In all cases, unless it never worked on that PC (which means that the problem might be in that PC's USB port), I'd strongly suggest to back up all data on another disk.
Oct 26, 2009 | Seagate Free Agent Go Small 12 GB USB...
When i connect my seagate via usb nothing comes up on my pc, the light comes on on the external h/d but nothing pops up on the pc? help please i need precious photos on it. thanks
have you try connect your pen drive to the same usb port, is it working?
If Pendrive is working but not the Seagate hardisk. Most propably is your USB power is not enough to support the External Seagate hard disk, you need to supply more power to the Seagate hard disk by using USB Y cable(1 end connect to Seagate hardisk where the other end got 2 USB connector to connect to your PC).
Jul 30, 2008 | Computers & Internet
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Windows 98 driver for FreeAgent
If your PC is still running Win98 then it probably has a USB version 1.0 port. I don't think the Faster USB version 2.0 devices will work properly even if you have the correct driver - i.e. you have a hardware version conflict. Try Purchasing a USB version 2.0 Daughter board for the PC and plugging the Seagate drive into that iinstead.
Jan 01, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate external hard drive problem
Hello, Did you try to use this drive on another computer? Did you have the same problem? Did you try using a different cable? I would try these things first in order to determine if the problem is with the drive or with the computer. Good Luck! Dr. Know
Dec 23, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent Pro Desktop - 320GB - 7200rpm - 480Mbps USB 2.0, 300Mbps External SATA ... Hard Drive Logo
136 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
