Question about Peg Perego John Deere Gator HPX Ride on Toy
2nd gear won't work
Can not get the drivers side rear tire to move in 2nd gear.
Works fine in 1st and reverse but not in 2nd.
Can anyone help?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath
Posted on Jun 13, 2012
3 Suggested Answers
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
SOURCE: will only drive forward in 1st gear, 2nd gear and
It is propably the gear box. Take the seat off and you will see the gears inside. Mine works only in 2nd and not the 1st or reverse. But I know it is the gear box since my husband replaced the 1st one a while agao. Just need to find the web site for the repacement part. Only cost us about $30 to fix last time. Hope this helps.
Posted on Jul 10, 2009
Only 1 wheel turns in 2nd nothing in 1st or reverse
you have a bad motor, whichever side isn't turning you need to replace that motor
Jun 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
Gator won't work in 2nd Gear
sounds like you have a bad motor, you'll need to pull the dump bed off to acess the motors and disconnect one and then see if it works
May 22, 2013 | Peg Perego John Deere Gator HPX Ride on...
Only reverse works. No foward gears.
No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
Do you have manual 1st? If so, can you shift through the gears...i.e. manual 1st to manual 2nd then 'D' then 'OD'??? Only 1st and 2nd gears use the forward sprag unless the LO/Rev clutch is engaged...i.e. 1st and 2nd if in "drive". If you can shift threw the gears manually then, yes, your forward sprag broke.
If no manual 1st then your sprag is not what broke. Sounds like you blew up the rear planet. If you pull the pan and find chunks of iron and steel, then that is probably what happened. If you have reverse then it is not the pump. If the pump was bad you would have no line pressure and it would slip in rev. or no rev. Not the beef sun shell either because you have rev., a broken sun shell would cause no 2nd, 4th and rev. gears. Either way the trans needs to come out and torn down and it will be easily found what went. Good luck and thank you for using Fixya.
Mar 06, 2010 | 1991 GMC C1500
1996 gmc jimmy won`t shift from 1st to 2nd
IF the abs dash light is on and if the speedometer is sluggish or not working at all, it is probably a bad speed sensor on the transmission. and easy fix under $40 for the part. Mine was stuck in second gear for a while then worked then it stuck in first gear and i had the CHECK ENGINE light on.
Dec 03, 2009 | 1996 GMC Jimmy
Will only drive forward in 1st gear, 2nd gear and
Jun 28, 2009 | National Little Tikes Hummer Yellow
Clutch slips
Hello, wheelies mm not good for your gearbox or clutch, 1st off is the gearbox working OK, does it jump out of 2nd gear under hard acceleration? then we can move on from this point,
Ian
May 26, 2009 | 2004 Triumph Daytona 600
Peg Perego John Deere Gator HPX Ride on Toy Logo
156 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
