Hello!i m buying from Chinavasion Car Rear View Camera with Wide Angle Lens + Up/Down Adjustment model [CVSH-CS25] and 1-DIN GPS Media Player with 7 Inch Touch Screen and DVB-T model CVHA-C21. And i need help with connection Car Rear View Camera with Wide Angle Lens GPS Car DVD with DVB-T and Bluetooth (1-DIN).I have a problem with the reverse camera.I compiled all the instructions that came with the dvd and camera excluded orange wire.At this writing wire camera but not written with as soon as the drafts.Camera in the aux mode does not work.Does the camera work in some other fashion? If it works in a different mode,how to run it? I need some detailed instructions for connecting the camera and dvid player. Camera works with other LCD monitor.When you connect to aux input on the front starani dvd player and camera to reproduce an image. When you connect with the entrance on the back starani dvd player parking provided for the camera, the camera does not work and can not reproduce the image. The instructions that came with the dvd player does not write anything about connecting the camera or how to reverse in its settings menu naparaviti play reverse image camera with DVD player.
If you have any problems with your car reverse camera then, I would like to say something that you have to prefer Car Reverse Camera service. As they provide the best service and fix all the issues regarding camera at an affordable cost. I also used their service to install a reverse camera in my car.
Hey mate i'm having the same problem did you ended up fixing it al all??
thanks
Contact to repairer
Reverse camera has video cable ,red and white cables. When in reverse the camera works well, but when the engine is on and in reverse, the screen will not show image , only interference . I know that the red cable is power from reverse feed , where do I connect the white cable?
