Question about UTStarcom CDM7025 Cellular Phone
How do you turn the ewtiquite of on a utstarcoom cdm7126
Hold down * key .....you can turn it on and off this way..
Posted on Nov 05, 2009
The hazard back lights wont quit blinking when car is running even when i pull the fuse on a 2002 buick regal
What fuse are you pulling ?
Hazard Lamps
The hazard warning switch is part of the turn signal switch. The turn signal switch receives battery voltage at all times through the HAZARD SWITCH Fuse. When the hazard switch is placed in the HAZARD position, battery voltage is applied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher sends a turn signal flasher signal to the turn signal switch. The turn signal switch provides all of the turn lamps and turn indicators with the turn signal flasher signal, simultaneously flashing them on and off.
Turn Signal Lamps
The front turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL Fuse. Battery voltage is then applied through the turn signal fuse circuit to the turn signal switch. When the turn signal switch is placed in the LH or RH position, voltage is supplied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the BCM. The turn lamps are permanently grounded.
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Feb 11, 2017 | Buick Cars & Trucks
I have a white screen on my cricket wireless phone cdm7126
unfortunately this seems to be a hardware issue. my guess is the ribbon cable that connects the board to the screen through the hinge is messed up. both my phones are doing the same thing. unfortunately the only solution i've come up with is getting a new phone.
Jan 24, 2010 | Cell Phones
Need drivers for utstarcom cdm7126
get it from www.download.com
please give me ratings....
Aug 21, 2009 | Cell Phones
NEED MY PHONE UNLOCKED
Try these two unlock codes:
##8856252633
**5732835736
and you need to hit send after.
:D
May 24, 2009 | Apex Digital AT2008 20" TV
Locked utstarcom model cdm7126
Call your cell phone company. They have a master code to unlock it. That should be the quick fix :)
Mar 18, 2009 | UTStarcom CDM7025 Cellular Phone
UTStarcom CDM7126 etiquette mode
hold star button on the phone and it will enable it
Feb 11, 2009 | UTStarcom CDM7025 Cellular Phone
Locked phone.
Try the last 4 digits of your phone number or 0000
Nov 25, 2008 | Nokia 1600 Cellular Phone
UTStarcom CDM7025 Cellular Phone Logo
69 people viewed this question
Top UTStarcom Cell Phones Experts
iphone service
buzzcola
Level 1 Expert
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
