Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Hotpoint G-157 washer
My washer just started leaking water. The outgoing water hose into the wash sink are okay. Looks like a cup or two come out from under the machine. How do I remove the top so I can look inside?
  • solomom Dec 31, 2007
    The washer (Whirlpool Ultimate Care II top loader) seems to be working OK but there is a little bit of water in the tray beneath the washer. It is in a small space so I can't get behind it - or on either side. Could I just be overfilling it? I've tried to wash smaller loads but it's hard to tell what's going on since it is in such a tight space.
  • Anonymous Mar 28, 2014
    How old is the washing machine
Get a small putty knife facing the machine insert it about 2 inches from the edge in the little crack between the top and body of the washer push in while lifting the top you should feel the spring that should get the top up but prob you have a leaking tub seal
Posted on Dec 30, 2007
The faucet leaks where the spray hose attaches to the spray head. Model 157-074r-st. The problem occurs when water is turned on. If the spray head is in the handle, water leaks below the sink. If the spray...
Yes the leak is the washer. You can get a new washer at any hardware store. Just take the damaged washer with you and have someone at the store help you.
Here is the washer size according to the manual 20X12X2.5
Page 2 of the link below.
http://www.blancoamerica.com/SPECIFICATIONS/157074R.pdf
Feb 27, 2011 | Blanco Classic Single Handle Faucet with...
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius wms38 1200spin Machine fills with water after wash cycle is finished and it is turned off
If the water is coming in after cycle has finished, then it is 1 of 2 possibilities.
1- A faulty inlet valve, replace it.
2-Water is syphoning back from the sink if it is connected to the sink waste outlet pipe, raise washer outlet hose higher up to solve problem
Nov 30, 2010 | Hotpoint Washing Machines
Hi, I'm looking for help with my hotpoint wmf740 washing machine.
A couple of possibilities here.
It could be a sticking water inlet valve, or water syphoning back into washer if the drain outlet hose is joined into the sink waste outlet.
To check which it is, turn off the water supply to the washer and leave for a day or two, if no water comes in, then it is a sticking inlet valve which will have to be replaced.
If water still comes in after turning it off to the washer, then it is the waste outlet pipe that will need to be lifted up higher to prevent water coming back into washer from sink waste.
Please rate my solution.
Thankyou.
Jan 15, 2010 | Washing Machines
Water leaking at rear
It is probably the hose washer or crimp thai is leaking.
I would suggest that you replace the hose to be on the safe side.
Jan 08, 2010 | Hotpoint Aquarius WD63 Front Load...
Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarious + flashing H 20 on display
H20 is indicating that you have no water coming in.
Check water is turned on,check hose(s) are not kinked, and finally check inlet valve.
If you are not sure if there is water to m/c, turn the tap off, disconnect the hose(s), and hold over sink and turn tap back on, water should come out, if it does not, then there is a prob with the supply.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore Elite
could be spash over be sure washer is as level as possible
Jun 01, 2008 | Kenmore 22422 Top Load Washer
Hotpoint Ultima dishwasher DF32
you are probably plumbed in under the sink for the drain hose. a common problem is water coming back down the drain hose when you empty the sink. if so take the drain hose up as far as possible in a swan neck. other possibility is a leaking fill valve
Jan 26, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
431 people viewed this question
Dan Webster
Dan Webster
Sal De
