Setting up the optimus pro sw-12
Just was trying to find an on-line users manual to properly set up my pro sw-12 w/ 2 lx5 speakers, and possibly also a klh model 2410 loudspeaker and 2 klh model 2410 rear channel speakers
Bowmans IT
  • 85 Answers
SOURCE: pinout diagram
Mail sent.
For anyone else.. Visit the motherboard's online manual via their website.
Posted on Nov 13, 2007
  • 5 Answers
SOURCE: avaya 2410 speakerphone
If the phone programming has been set to 2-way and you have reset the phone. Either by unplugging it and waiting for a few minutes then plugging it back in or from the idle state press the "MUTE" key and then dial R E S E T on the keypad. If after this it will still not work as 2 way then it is most likely a faulty phone.
Posted on Feb 11, 2008
  • 347 Answers
SOURCE: users manual
super old model and no manual available online. What info do you need? Whistler does have tech info if oyu click on radar detectors and then on the left pane - click on Additional Models. At the pull down menu - select 1190.
Posted on Jun 13, 2008
VOTIT
  • 2071 Answers
SOURCE: HTS9800W/12 and rear speakers
click this site:
http://www.avforums.com/forums/archive/index.php/t-378942.html
Posted on Jul 10, 2008
SOURCE: Audyssey won't initialize the left rear channel speaker input during set-up
had the same problem found that the rear speakers were connected to the wrong inputs on the receiver, try changing them i think you will find that this will work
Posted on Sep 14, 2008
How to reset the Kenwood vr-716
Unplug power cord from the wall outlet, then plug it back IN WHILE HOLDING DOWN THE POWER KEY = only for U.s.a and Canada
For other Countries With the power cord plugged in, turn the POWER key
OFF. Then, while holding down the ON/STANDBY
key, press POWER.
Memory back up function
Please note that the following items will be deleted from the unit's
memory if the power cord is disconnected from the AC outlet for
approximately 3 days.
• Power mode. • Distance setting.
• Input selector settings. • Input mode setting.
• Picture output. • Midnight mode setting.
• Speaker ON/OFF. • PRO LOGIC II mode setting.
• Volume level. • Broadcast band.
• BASS, TREBLE, INPUT level. • Frequency setting.
• Dimmer level. • Preset stations.
• MD/TAPE settings. • Tuning mode.
• Listen mode setting. • CINEMA EQ ON/OFF.
• Speaker settings. • LOUDNESS ON/OFF.
• SW RE-MIX ON/OFF.
Cautions
MODEL PARTS # REMOTE CONTROL # DESTINATION
VR-705-SA A70-1612-05 RC-R0626 K1P1
VR-707A A70-1617-05 RC-R0824 K2P2
VR-716A A70-1617-05 RC-R0824 K4P4
REMOTE CONTROL vs MODEL
DIFFERENT POINT
ACCESSORIES / CAUTIONS
Model Service Manual Surround Display Sub
VR-705 B51-5840-00 X09-6740-10 -
VR-705-SA - X09-6740-11 X25-6600-10
VR-707 B51-5840-00 X09-6750-12 X25-6520-12
VR-707A - X09-6750-14 X25-6610-10
VR-716 B51-5840-00 X09-6750-11 -
VR-716A - X09-6750-13 X25-6600-10
Note:
A different information will be available from this service manual. Pls refer to original service manual(B51-5840-00), too
Nov 13, 2016 | Kenwood Audio Players & Recorders
How to remove optimus lx5 speaker from cabinets
For help on these try Audiokarma.org.
The screws holding the front of the cabinet on are underneath the rubber sockets that the grill fit into.
Aug 08, 2014 | Radio Shack Audio Players & Recorders
Connect optimus lab 1100 to macbook
The type of computer is not relevant. This turntable provides output at nominal "line level" and can be connected to your MacBook with a properly shielded audio cable through the audio input.
For best results, you might want to disable automatic-gain-control (AGC) in the "Sound" preferences pane in the "System Preferences" panel, and set the level manually such that the input does not overload.
As I mentioned above, the signal level is nominally "line level", and that can mean very different things depending on context. You might find that using a passive volume control (potentiometer) between the turntable and the computer's analog-to-digital converter can greatly improve the quality of sound.
Jun 20, 2014 | Apple MacBook Pro Laptop Computer with...
Using without parking break
Hi James,
Page 27 of the installation manual (http://www.wwstereo.com/_files/155788/documents/Kenwood--Manual.pdf) shows a connection to the parking brake light circuit. It is the Light Green wire labeled "PRK SW" shown below.
If it is connected the way it is drawn, the PRK SW wire is connected between the lamp and the switch that opens and closes depending on the position of the parking brake (set or not). 12 volts is always present from the battery to the top of the lamp. It passes thru the filament to the wire that goes the top of the parking brake switch. So, when the brake is OFF or disengaged, the lamp is off and 12 volts is present on the PRK SW wire to your Kenwood GPS. When you set the parking brake, the ground (symbol is the funny slanted lines under a horizontal line) just under the brake switch passes through the switch and changes voltage at the PRK SW to "ground" or 0 volts. When this happens, the ground on one side of the lamp with 12 volts on the other side of the lamp - make is turn on.
So, what does this mean? Simply tie the PRK SW wire to any grounded metal and the Kenwood will think the parking brake is always set - for as long as it is tied to ground. You can check it with a simple voltmeter to be sure. Set the meter to 12 volts or more, touch black lead to ground & the red lead to the PRK SW wire. Kenwood should only work when at 0 volts (brake set). Release the brake - meter shows 12 volts & the Kenwood shuts off.
I hope this helps & Good luck!
Apr 09, 2014 | Kenwood DNX570HD
Speaker hook
Hi it's a problem in the set up . This model , like few other in the line have the possibility to switch the "back speakers" ( through harness or RCA) into "BASS SPEAKERS" what give you a possibility to hook up a Sub without an extra amp .
To switch it back just follow the Section 2 / Sw control of this link http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-3300UB_OwnersManual0902.pdf
Dec 19, 2013 | Pioneer DEH-3300UB Radio-CD-MP3-Digital...
I hv a Denon AVR 3805, i tried to set it up but after doing all the necessary, i found out that it was only running on 3 speakers (FL,FR & SW). I did connect the center speaker but the sound just...
SW means sub woofer, not necessary means center speaker in all receivers. Instead of setting 5ch stereo, if you have 3 speakers. try to set "3channel" or "simulated". If you own more than 3 speakers, you may refer to the user´s manual to correctly wire them to get the full sound.
Sep 18, 2010 | Denon AVR-3805 Receiver
I need user manual of Wharfedale topaz SW-12. Where I find it. thaks
WHARFEDALE Topaz SW-12 Subwoofe
connected to Sony STR-DE975 at the sub-
woofer out-put only hums, ??
thanks
Sep 06, 2010 | Wharfedale Topaz SW-12 Subwoofer
Sony SW no sound
does this sub have an LFE output? if so, connect that to the LFE input on the reciever and make sure it is set up properly in the set up menu in speaker configuration. if the sub has speaker line input outputs, connect speakers to input of sub and out of sub to amp/recvr
May 10, 2010 | Sony SA-WM40 Subwoofer
Ba745 user manual
I'm sure that there is some special software available, but its unnecessary. You can just plug them in and have a listen. Sorry, I'm not sure where to find a manual.
Mar 19, 2010 | Boston Acoustics BA745 Computer Speakers
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
1,272 people viewed this question
 Grubhead
Grubhead
