Question about 3Com OfficeConnect Wireless Router
Unable to access router address on browser(Explorer)to set it up. 192.168.1.1 takes me to the web pages where other people are having the same problem.
  • g_c1 Oct 09, 2009
    Thanks for your suggestions, unfortunately they didn't help me get into the router settings. The gateway address was 192.168.1.1, so I changed this to 192.168.200.254 but browser was unable to find it. Any other suggestions please?
  • 728 Answers
Hi g_c1,
If you haven't changed the default IP, then your trying the wrong IP #. The default IP for that Router is 192.168.200.254. See if that helps.
Also, you can always go to the Start and Click on Run, and at the line enter cmd. When you get to dos type in ipconfig /all this will give you a list of all IP assigned to that computer. The one that your looking for is called the Gateway. That line has your IP address of the router.
Good Luck
Mark
Posted on Oct 08, 2009
Testimonial: "Thanks for your suggestions, by going into CMD and entering 'ipconfig/release *Con*' I have been able to access the router settings. I have to do this"
  • Mark Taylor
    Mark Taylor Oct 10, 2009
    Ok,
    Confirm that the physical connection between your computer and the Gateway is OK, and that the link status LEDs on the Gateway and NIC are illuminated and indicating the same speed (10Mbps or 100Mbps). Some NICs do not have status LEDs, in which case a diagnostic program may be available that can give you this information.
     Ensure that you have configured your computer properly.
    Setting Up Your Computers. Restart your computer while it is connected to the Gateway to ensure that your computer receives an IP address.
     When entering the address of the Gateway into your web browser, ensure that you include the full URL including the http:// prefix (eg. http://192.168.1.1). Or the (http://192.168.200.254)
     If you cannot browse to the Gateway, use the winipcfg utility in Windows 95/98/ME to verify that your computer has received the correct address information from the Gateway. From the Start menu, choose Run and then
    enter cmd, at the prompt type the ipconfig /all. Check that the computer has an IP address of the form 192.168.1.xxx (where xxx is in the range 2-254), the subnet mask is 255.255.255.0, and the default Gateway is 192.168.1.1 or whatever. (the address of the
    Gateway). If these are not correct, use the Release and Renew functions to obtain a new IP address from the Gateway. Use the ipconfig command-line utility to perform the same functions. Type in ipconfig ? and it will give you all the commands and how to enter them.
     If you still cannot browse to the Gateway, then use the Discovery program if you still have it, if not you can download it from HERE. Just enter your model number of the Office Connect, as you see there are a lot of them.
    And restore the driver for the router.
    If that doesn't work, then their is probably something mighty wrong with that router.
    Good Luck,
    Mark
  • Mark Taylor
    Mark Taylor Oct 18, 2009
    If that getting you to the router then great. You can also renew your ip's with the cmd ipconfig /renew or ipconfig /renew **
    ** equals the device's name first two digits.
    Great to hear you got access
    Thanks
    mark
Linksys sd208 reset
The reset button is usually at the back of the router. If you are unable to locate it you can reset it using a web based set-up page. Make sure you connect your router to a PC using wired connection and perform the following steps:
Step 1:
Launch a web browser like Internet Explorer.
Step 2:
In the Address bar, enter "192.168.1.1" as the router's default IP address then press [Enter]. If this doesn't work or if the IP address of your router has been changed, enter it instead.
Step 3:
Enter "admin" in the Password field then leave the User name blank. If you have set up a User name and Password for your Linksys router before, enter your personalized credentials instead.
QUICK TIP: For Linksys Smart Wi-Fi Routers, you can enter "http://myrouter.local" on the Address bar to access its web-based setup page.
The router's web-based setup page should now appear from here you can reset the router.
for more info browse this link: http://kb.linksys.com/Linksys/ukp.aspx?pid=80&vw=1&articleid=3676
Sep 19, 2013 | Computers & Internet
Where re my router settings
they are normally accessed by going to the router's settings page on a computer connected to your network, preferably hard wired as opposed to a wireless connection. The address of this page varies by make, model, and network setup but is most often 192.168.0.1, 192.168.1.1, or 192.168.100.1 You would just pull up internet explorer and enter the address into the address bar.
Mar 07, 2011 | Computers & Internet
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G Broadband Router
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
I need to get into my nat settings
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
HELLO SIR, GOOD DAY TO YOU.. I JUST WANT TO ASK SOME ASSISTANCE WITH REGARDS TO MY NEW ROUTER .. ASUS RX3141, I CANT CONFIGURE THAT IN OUR PC AND LAPTOP. I DID EXACTLY WHAT IT SPECIFIED IN THE MANUAL AND...
You typically need to set up a router through a web browser (such as internet explorer). They are typically given IP address 192.168.1.1 as default, so you could try attaching the computer to the router with a network cable then typing
192.168.1.1
into the address line of internet explorer. That should take you to the router set-up page, where you can enter your username & PW
Sep 09, 2008 | ASUS RX3141 Router
3Com OfficeConnect Wireless Router Logo
461 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
