Question about Toshiba Satellite 4030Cdt Replacement Part
My laptop is hanging, not starting due to limited space, it is requesting for cleanup, but I can't cleanup when it has failed to start, what can I do?
  • 107 Answers
Have you tried to boot on a safemode? press F8 and boot using safemode, there you can configure the errors.
Posted on Oct 08, 2009
Laptop fell and keeps hanging
Follow these guidelines::
Free up wasted space with Disk Cleanup tool
Defragment your hard disk drive
Remove unused programs
Install and run antispyware software
Disconnect unused network connections:
Click Start, and then click My Computer.
On the Tools menu, click Disconnect Network Drive.
Select the network drives that you no longer need, and then click[b] OK.
Stop Unwanted startup programs:
Start > Run > write msconfig > Click on StartUp tab
Deselect the programs you want to stop
If this didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of hanging problem
Oct 07, 2013 | Acer Computers & Internet
It hangs while working on internet
Laptop hang issues can be a frustrating issue for the user and a tedious problem for a technician.
The variety of causes for this event are staggering, but many can be diagnosed in a few simple steps.
Peripheral Issues
USB drives, inserted before boot, will cause a hang.
Remove all such devices and media (such as CDs and floppy disks) before booting your laptop.
Software Causes
Press "F8" at boot and press "Last Known Good Configuration" to take your laptop to a previous working boot. Starting your laptop in "Safe Mode" by pressing "F8" at boot will help
you check for software causes for a hanging laptop.
By turning off unnecessary processes, this mode allows you to run anti-spyware and antivirus software to clear malware that hinders performance.
Perform a check disk by right-clicking on your "C Drive" found in "My Computer."
At the "Properties" link, press the "Tools" tab to schedule error checking.
Reboot your laptop and let it perform this check.
Hardware Causes
Verify that your RAM is seated correctly by removing it carefully from under its access door on the bottom of your laptop and reinserting it.
Do not touch its gold contact points, as this may damage the memory.
Download the hard drive manufacturer's diagnostic software to test the integrity of the hard disk.
If you have access, run a professional hardware diagnostic suite to check the motherboard and CPU.
Boot with the battery removed to verify that there is not an issue with power conflicts.
Final Considerations
Checking the "Event Viewer from Administrative Tools" located in "Control Panel" (XP only) can also shed light on potential causes.
Performing a repair installation of Windows can address missing files, registry errors and corrupted system files without damaging your data.
This process requires your original Windows disks but is often quite useful.
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking startall programsaccessoriessystem tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
this should speed up your computer
Sep 05, 2013 | Acer Computers & Internet
Slow processing
Acer brand laptop computers are designed to be small, portable units that are great for logging onto the Internet and checking email on the go.
As your Acer laptop ages, you may start to notice that it runs a little more sluggish than it used to. As Acer brand laptops run on the Windows operating system, luckily there are a few built-in tools that you can use to boost performance and generally speed up your machine without spending any additional money.
Use the "Disk Cleanup" tool. This tool is built into all Acer laptop computers and is accessible by clicking on "Start," then "Programs," then "Accessories," then "System Tools."
Disk Cleanup will remove any files left behind by programs on your Acer laptop computer that are no longer needed.
This can free up valuable hard drive space and generally give your Acer laptop computer a bit of a performance boost.
Use the "Disk Defragmenter" tool.
As with Disk Cleanup, this tool is built into all Acer laptop computers and is accessible through the same folder in the "Start" menu.
Disk Defragmenter physically rearranges the way bytes of data are stored on your hard drive, making it easier for your operating system to access pertinent information.
As it will take your computer less time to find the information you're requesting, your computer will speed up a great deal.
Get anything you can off of your hard drive. In order to keep the price down, Acer laptop computers tend to come with smaller hard drives than full sized laptops.
As a result, hard drive space can be very precious.
The more data is stored on a hard drive the longer it will take your operating system to sort through everything and find the files you're trying to access.
If you empty any files you don't need onto a flash drive or external hard drive, you can generally improve the speed of your Acer laptop computer a great deal.
also
Aug 02, 2013 | Acer Extensa Computers & Internet
Acer laptop hanging
Peripheral Issues
Software Causes
Hardware Causes
May 16, 2013 | Acer Aspire 5742 Notebook
Aspire5551 hangs at starting windows
Shut down, unplug, remove battery, plug in ,reboot. Try a system restore/recovery, use this procedure: http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Jan 15, 2013 | Acer Aspire 5551 Notebook
My msi laptop is hangs when if i open it.. i cant. use any key even the enter key to open the windows
Laptop Hanging Problems Laptop hang issues can be a frustrating issue for the user and a tedious problem for a technician. The variety of causes for this event are staggering, but many can be diagnosed in a few simple steps. Peripheral Issues USB drives, inserted before boot, will cause a hang. Remove all such devices and media (such as CDs and floppy disks) before booting your laptop. b> Software Causes Press "F8" at boot and press "Last Known Good Configuration" to take your laptop to a previous working boot. Starting your laptop in "Safe Mode" by pressing "F8" at boot will help you check for software causes for a hanging laptop. By turning off unnecessary processes, this mode allows you to run anti-spyware and antivirus software to clear malware that hinders performance. Perform a check disk by right-clicking on your "C Drive" found in "My Computer." At the "Properties" link, press the "Tools" tab to schedule error checking. Reboot your laptop and let it perform this check. Hardware Causes Verify that your RAM is seated correctly by removing it carefully from under its access door on the bottom of your laptop and reinserting it. Do not touch its gold contact points, as this may damage the memory. Download the hard drive manufacturer's diagnostic software to test the integrity of the hard disk. If you have access, run a professional hardware diagnostic suite to check the motherboard and CPU. Boot with the battery removed to verify that there is not an issue with power conflicts. b> Final Considerations Checking the "Event Viewer from Administrative Tools" located in "Control Panel" (XP only) can also shed light on potential causes. Performing a repair installation of Windows can address missing files, registry errors and corrupted system files without damaging your data. This process requires your original Windows disks but is often quite useful. Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 if you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If youre not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer Hope this helps.
Jan 13, 2013 | MSI MS-U135DX-1679ZA Netbook
My laptop desktop windows 7 always hang
Peripheral Issues
Software Causes
Hardware Causes
hope this helps
Oct 24, 2012 | Computers & Internet
Two days ago.videos was working and suddenly the netbook was hang and then i shut down the netbook and after that it is not starting.
It is possible that the Samsung Go N315 netbook fails to operate due to lack of system space.
This might lead to sudden shut down in the netbook.
This usually happens due to some unwanted files in the netbook which occupy significant amount of space in the hard disk as well as system memory.
You could resolve the issue by removing all unwanted data through methods like software testing, manual methods etc.
Get more information to fix Samsung Notebook shutdown suddenly . Hope this information helps you.
Jun 24, 2011 | Samsung N150 (36725723009) Netbook
My laptop is really slow
It could be due to clogged Registry. Use a good registry cleaner to do that. Even I had the same prob. my laptop used to take 20 mins to boot. After cleaning the registry it runs now.
Sep 17, 2009 | Gateway MT3705 Notebook
Hard disk space
My guess is that it is due to temporary files on your system. Check to see how much space the program takes up. Also try using Disk Cleanup to cleanup your hard disk. Disk Cleanup is located under accessories.
I think it might be helpful for us to do a live chat, inside or outside of FixYa, your choice. Drop me a email at suvayanr10@gmail.com.. Let me know if you're interested. I'd be glad to talk one on one with you.
Aug 14, 2008 | Dell Latitude C640 Notebook
Toshiba Satellite 4030Cdt  Replacement Part Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
