Question about Nintendo Wii Console
The red light is on constantly on my wii machine, where it should be umber, I have tested my a/c lead on anther wii and it work, now I know it is the wii console which has the fault. what can i do. thank you
  • 57 Answers
It's nothing you should be worried about. The Wii that has the red light instead of the amber light simply doesn't have WiiConnect24 on. When you activate WiiConnect24, the light should change to amber.
Posted on May 16, 2010
My 95 nissan pickup has light issues. I can't seem to figure out what causing the night not to work I have tested the fuse block and all leads into the illumination control switch but don't know where
According to the wiring diagram, you should have two 15amp fuses powering the headlight switch. One wire is red and the other is red white.
Power out of the switch is pink blue for the tail lights, and red with green, blue, black, and yellow for each headlight circuit.
Diagram courtesy of autozone.com
Feb 28, 2013 | Cars & Trucks
Head unit not getting the right constant power
normally when an aftermarket stereo is installed the yellow wire is for constant power gets connected with the ignition power wire and what you said is what happens in result. get a multimeter, set it onto dc volts and put the black lead onto something metal and then id use the red lead to test wires for a constant 12volts when key is in the off position. Once a wire is found connect it to the yellow wire of the stereo
Feb 19, 2013 | 1999 Acura Integra
My wii system will not turn on. every time I hit the power or eject button the red light will flash yellow and then turn off. If I unplug the cords the light will be red again, but I push the power button...
Hi, you may just need to reset the power lead, to do this unplug it from the wii, then unplug it from the wall, now leave it all unplugged for 5 min this will allow the power lead to reset then plug it all back in and give it a try.
if after doing the above it still dont work then the chances are the wii has over heated so check if you have any warranty left as this fault is covered, if you dont then you need to find someone who can reflow the solder for you on the 2 main chips under the heat sink, this is not easy to do and could cause more harm then good so be warned.
let me know what happens after unplugging the lead ok
Nov 28, 2010 | Nintendo Wii Console
Wii suddenly stopped working and will not switch on anymore. when we now plug in the red standby light is on then when i switch power on this goes out and no light is showing have tried alternative powere...
It sounds like an issue with the power supply. Strictly speaking, I've had little experience Wii console hardware, but in my dealings with other electronic devices and video game systems those symptoms would indicate the power supply board has shorted. Just my guess, though. Sorry I couldn't give you better news!
Jan 03, 2010 | Nintendo Wii Console
Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
Dec 29, 2009 | Nintendo Wii Console
My nintendo wii power light is yellow
The wii power light is yellow because you have wiiconnect24 turned on in the wii system options. Wiiconnect24 constantly keeps your wii connected to the internet by staying in a low power mode, if you receive any messages while int his mode the disk opening will flash blue. If you don't want this option just go into the wii systems settings and turn it off. If you wish to have it but want to turn it fully off just hold the power button on the main console until the power light turns red.
Dec 28, 2009 | Nintendo Wii Console
My handsets wont sincronise with the system, I have fitted new batteries
Follow this procedure:
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
* If multiple Wii Remotes do not work, or you only have one Wii Remote, a repair of the Wii console is necessary.
Oct 20, 2009 | Nintendo Wii Console
Red lights
this might be your scart lead that is faulty OR the A/V port on your console itself. to test this out borrow another scart from a friend and try that. if it works then you know that its your scart. but if it does the exact same then you know it is your machine thats faulty and needs repairing.
XboxRepairKit.co.uk
Apr 13, 2009 | Microsoft Xbox 360 Arcade
Wii remotes have stpped sending signals.
When you first press a button on the Wiimote, how many lights blink? If the answer is 1, then your batteries may be too low. 4 blinking lights mean that you have fully charged batteries.
Other than that, you may want to consult the user manual with regards to re-syncronizing your Wiimote to the console. If you don't have the manual any more, and you have at least two blinky lights, then press the red syncronizing button on the console first, then the corresponding button inside the battery cover on your Wiimote. Reboot the Wii and see if it works.
Mar 22, 2009 | Nintendo Wii Remote Controller
HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Feb 04, 2008 | Hotpoint Washing Machines
Nintendo Wii Console Logo
48 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
