Have a yamaha reciever with 2 hdmi inputs and 1 output aong with upscaling of composite inputs. when i connect my blu ray player through the reciever it will not appear on the tv. if i connect the blu ray directly to the tv it works. i have a hdmi extender fitted aswell. also the reciever will not upscale composite inputs. any answer to the problem????
    Scholar:
  • 125 Answers
Depending on the model of your Yamaha, you will have to go into setup of it. In there go to the input settings and select what should be done. Example: for DVD select HDMI as input. I take it you are using the HDMI out as well? This is what I had to do on my RX-V3800n
Hope this helps.
Posted on Oct 08, 2009
How do I connect a bluray which only has HDMI output to the TV
If your TVs HDMI input port is used you can use a splitter like this one: http://www.amazon.com/gp/product/B00OHHG768?keywords=switching%20hdmi%20splitter&qid=1456943391&ref_=sr_1_1&sr=8-1
to connect another HDMI device to the TV
If your TV does NOT have an HDMI input you need to convert the HDMI output from the blu-ray to RCA like this one:
http://www.amazon.com/Cater-Mini-Composite-Converter-Input/dp/B0149M9WFI/ref=sr_1_1?ie=UTF8&qid=1456943578&sr=8-1-spons&keywords=convert+hdmi+to+RCA&psc=1
but this actually will reduce the high blu-ray quality to a lower resolution
Mar 02, 2016 | Televison & Video
How can you show me a diagram on how to connect my apex ad1115 digital dvd player to my JVC black crystal series LEDtv model BC50R
Composite video outputs of DVD to composite video inputs of tv.
Or HDMI output on DVD to HDMI input on tv.
If no matching sets you can always get adapters to do the deed.
Oct 27, 2015 | JVC Televison & Video
Connections for dvd player to tv
can be done 3 or 4 ways::need to look at outs on player and ins on TV.
HDMI; composite; s-video; RCA [please no]; RF [even worse]
look at what the player can output [normally all active at the same time]::find the highest resolution the TV can accept::get the proper cabling::hook it up::set TV to that input [usually able to name them {antenna, cable, hdmi 1-x; svideo 1-x, composite}
Feb 19, 2012 | Magnavox Televison & Video
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
Oct 12, 2011 | Element Electronics EDBCO11 Blu-Ray Player
Can I use a blue ray with my tv?
Blu-ray players can be connected and used with any Television that has at least Composite video inputs. But the only way to access the high def is through either a HDMI connection or your Component Video connections. You DO need an HD compatible TV to see any benefits of Blu-ray. Check the back of your TV your RCA model should have 1 set of the Syncroscan HD component input jacks and be sure the Blu-ray player has the component out jacks since they are being phased out.
Just be aware of the following:
As of January 1 2011, all Blu-ray players that reach the market will be Image Constraint Token enabled as per the industry AACS Adopter agreement. What this means is that new Blu-ray players will only be able to output high definition content over HDMI. Film studios will be able to embed an Image Constraint Token on their Blu-ray discs restricting the Blu-ray player from outputting the image in HD over an analog output, such as component. Instead, images will be sent over component will be constrained to a maximum resolution of 540p.
The move is part of a strategy that is designed to move consumers to digital-only connectivity so that by 2013 all analog outputs on Blu-ray players will be phased out. Studios have not been permitted to embed this technology into Blu-ray discs prior to December 31 2010, so discs purchased prior to this date will not have their image constrained. However, users will now need to look for the Image Constraint Token on the packaging of Blu-ray discs released after January 1 2011, if they still rely on component out for their Blu-ray player.
Jan 30, 2011 | RCA Scenium HD65W20 65" Rear Projection...
I have a VL470M and am trying to connect a LGBD570 Blu-Ray through HDMI. It works fine through the composite input, but the HDMI says "no signal". Am I doing something wrong?
There are two possible issues. 1) The resolutions are mismatched. (output of the player and input of the TV) 2) the player can not confirm that the TV supports HDCP over the HDMI connection. Only 3 of the 4 HDMI ports are HDCP (high def copy protection) compatible.
Try a different HDMI port and make sure that you have the input set to the correct HDMI port. (There is an input button on the side of the TV as well as on the remote.)
The easiest things to check are turn off the Blu-Ray player and then turn it on again. Then press the Home button and navigate to the Setup Menu. Select Display and press the right arrow button, then select Resolution and press Enter. Then set the desired resolution and press Enter to confirm the selection. (Your TV should support 1080p from the Blu-ray player.) Then turn off the player since changing the resolution can lead to video issues.
I hope this helps.
(the manuals for the TV and the blu-ray player are available on line: http://www.vizio.com/vl470m.html and http://www.lg.com/us/tv-audio-video/video/LG-blu-ray-dvd-player-BD570.jsp Click on Support on either site.
Nov 13, 2010 | Televison & Video
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
My player seems not able to upscale the signal from my antennea and DVDs
Upscaling will only occur when playing DVDs. You have to use an HDMI connection from the DVD player to the tv. For upscaling of DVD's you will also have to setup the upscaling resolution in the DVD player's setup menu. Be sure to set the resolution to one that your tv will support.
If your tv does not have a HDMI input, then you will not be able to use the upscaling feature.
Upscaling will not occur on antenna signals. This is not possible because the hardware (inside DVD player) is only meant to upscale DVD video.
Again, to upscale DVDs ONLY, you will have to have an HDMI cable going from DVD player to TV, set up your upscaling options on your DVD setup menu and have a TV that has a HDMI input and is capable of recieving the upscaled resolution you have set your DVD player to.
If you have any further question regarding this, let me know!
Oct 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
No video
I am not sure if you have gone into the Receivers Menu or not? If you have NOT! Then please try this: Go into the Receivers Menu (If you do not see the MENU on the TV you can hook up a Composite (Yellow) Cable from the Receivers Monitor Out (Yellow) and select the Input on the TV that you plug into) Look in the Menu for Inputs or In/Out Config. or Video Setup. Look for the Input that you are using for that Device. Change the Video setting to HDMI. I also recommend doing this for you Audio as well. Find the Audio Inputs and MATCH each Input to there DEVICE and CABLE (Connection) Being used. Also check in the Receiver Menu for UPSCALE or UPSCALER. Turn this on or off to see if your TV is Compatible! Hope This Helps! P.S. Check the Manual for Upscaling Capabilities NOT all Receivers upscale and route the SAME!
Jan 12, 2008 | Yamaha RX-V861 Receiver
138 people viewed this question
 Grubhead
Grubhead
