Question about BenQ FP737S-D 17" LCD Monitor
Benq lcd Hi My benq lcd does not lid up and i believe it a circuit board problem. Where can i purchase a circuit board for my benq lcd. thanks
    Champion:
  • 220 Answers
WHich model is this?
Samir
Posted on Feb 29, 2008
BenQ Q24W5 LCD monitor circuit diagram
HI.............
Repairing BenQ 17′ LCD Monitor
I came across a common fault problem in BenQ 17′ LCD Monitor. The problem is have power but no display. Once you has opened the LCD cover, check the pico fuse for open circuit (very common), the push pull transistors C5707 for short circuit and the Buck royer circuit p-channel fet FQU11P06 also for short circuit too. For your information, if you can't get the FQU11p06 you can always use FU9024N as a replacement. Resolder all the high voltage transformer pins and replace the components above and I'm sure you will bring back the life of this BenQ 17′ LCD Monitor.
You may go to this fairchild semiconductor website to download the spec of the FQU11P06 P-channel FET.
http://www.fairchildsemi.com/ds/FQ/FQU11P06.pdf
GOOD LUCK.............
Sep 23, 2011 | Computers & Internet
I have a benq t701 with power problems
faulty power board... possibly caused by blown capacitors..
Jul 03, 2009 | BenQ T701 TFT 17" LCD Monitor
White screen
I believe they are two 1000uf 16 volt... there are two side by side and they are tall.
Robert
Sep 15, 2008 | BenQ FP737S-D 17" LCD Monitor
Replacing of defective MAin Logic Card for my BenQ LCD TV 2050
Replacement of a main board might be tricky and not worth the money, I am not sure if you would troubleshoot or replace yourself.
- Have you opened the TV and seen the board?
- Once you open, can you actually remove it?
- If this is fairly new, (3-5 years) lead free solder would have been used, and prone to cracks
- Inspect every solder joint under high power microscope.
- BGA parts need X-ray, tough to get this done if you are not a solder/circuit board house
- If you apply pressure to BGA, when powered up, it may connect and work, this is a troubleshoot technique.
Hope this helps
Dec 17, 2017 | BenQ DV2050 20 in. HD-Ready LCD Television
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
BenQ FP71E doesn´t gives video
This suggests there is a dry joint on on the printed circuit board. I would go over with a soldering iron on all joints that look suspect.
Jun 02, 2008 | BenQ FP71G 17" LCD Monitor
Screen has power but is black
Looks like many faukty parts on the inverter board.. replacing will not be of much help as it will soon start get troublesome once again. I would suggest that replacing the LCD inverter board is a smarter solution. Hope this helps!
Good Luck!
Apr 15, 2008 | BenQ FP71G 17" LCD Monitor
Benq screen shuts down when pc is plugged in
If it's a 71g and not 71g+ resolder transistors 2sc5707 on invertor board along with grey condensers and inverter transformer.This should solve the problem if it was display shutting off with power led remaining on.Otherwise check power section.
Feb 24, 2008 | BenQ FP71G 17" LCD Monitor
BENQ FP731s Monitor Problem white blank screen
You have a serious problem. ie. only the back light is working in your monitor. You might need to replace the TFT associate components.
May 06, 2007 | BenQ FP731 17" LCD Monitor
BenQ FP737S-D 17" LCD Monitor Logo
183 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
