Question about HP Hewlett Packard LCD Display for Pavilion zv5000, zx5000, Compaq r3000t, r3200
HP LCD Display problem
I have common problem with HP Laptop LCD, I just bought a year ago but lately my laptop screen color display not working good, a patches of white have seen, I try on external monitor attached to my laptop, there is no problem and it working right. I think the LCD was the cause and it display poorly.
I hope HP will work on this issues, otherwise there products will avoided by the consumers
  • 403 Answers
Right click your mouse button while at your desk top. Click on the settings tab, what is your screen resolution at. Try changing this by either going down or up. What is the Color quality at try changing this to 16 or 32 which ever one your not at. Check the display area what board do they have listed for you. Are there any other options. As you try and make these changes the background of your screen should change and you should be asked if you want to keep it or go back to what was before. It's just going to take some patience trying to correct this. What is the brand and model of your computer and what operating system are you using. You can go to HP site and download the display drivers four your unit. Just go to this link below. Go to support and drivers tab and put in your unit. Just copy and paste into your browser.
http://welcome.hp.com/country/us/en/welcome.html#Product
Hope this helps, let me know if I can help you with anything else.
JimmyC
Posted on Oct 08, 2009
Hi I have HP dv6767tx laptop which i purchased in april 2008 But 1 year ago, all of a sudden a bright strip around 1 to 2 inches in thickness appeared on the extreme left of the lcd screen. Affected...
very sorry to tell you that the lcd has gone bad because your laptop shows exact symptoms of this case.
As per what some HP costumers have told me HP takes this as a physical damage and does not give them a warranty even if it is in the warranty cover
Finally you will need to get it replaced
This is the most expensive fix after a motherboard and may cost you $180 or 8000-9000 INR
Jul 26, 2011 | HP Computers & Internet
Laptop screen went black
When I opened my laptop this morning my computer won't come on. The screen is totally black. I took out the battery and put it back in ---- still nothing. I plugged it in with the power cord --- nothing! What is wrong with my HP Compaq Presario CQ60?
Jan 04, 2010 | Compaq Presario CQ60-220US PC Laptop
A thin line appears in the display
It could be the video card or the LCD display is going bad. I would suggest contacting HP support regarding this matter. Hopefully you registered it with them when you bought it. Most computers have a one year warranty from the manufacturer. Did you buy an extended warranty with this machine? If you have an extended warranty from the place you bought it, contact them.
Dec 01, 2009 | HP Pavilion dv4000 Notebook
Display
your laptop display mass color, it is not the issue of inverter.
there are two situations:
1) mass color you can not see any messages like letter or picture
2) mass color with some or any messages you can see.
above situations you need to check LCD sreen cable connection between LCD socket and the motherboard socket, plug back properly.if not fixed, there are some tips you may consider:
1) change the Ram if the display ram is not isolated.
2) the LCD cable damage need to change or
3) LCD screen damage need to change or
4) finally the motherboard display chips damage(rare)
May 07, 2009 | HP Compaq Presario V2000 Notebook
HP Laptop black screen on boot, TV source works
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 11, 2009 | HP Pavilion dv9500t PC Notebook
White area in LCD screen with colored vertical lines
LCD needs to be replaced.
Common problemcalled "Tab separation".
Nov 24, 2008 | Acer Aspire 8920-6671 Notebook
HP Pavillion ZD8000 display problem
Before you invest any further, try the lcd inverter http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/ I have seen them for real cheap. If you take off your bezel cover underneath the display you'll find the inverter9147480.jpg or if necessary you can get a tech to help install. Usually theres a series of beeps when you get a blank screen. Hp pavilion laptops also get hot on the keyboard after a while from long term use and zd 8000 came out about 4 years ago so the display should be a pretty good looking glossy screen. Those are nice laptops to work with by the way.
Oct 12, 2008 | HP Pavilion zd8000 Notebook
Hp pavilion f1523 lcd monitor
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Oct 02, 2008 | HP Pavilion zd8000 Notebook
HP NX 6110 Laptop problem
IT'S A CHIPSET PROBLEM - faulty connection resolved (or better-patched) with pressure on it: see here and good luck ! http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1260029524885+28353475&threadId=1096080
Nov 19, 2007 | Computers & Internet
HP Hewlett Packard  LCD Display for Pavilion zv5000, zx5000, Compaq r3000t, r3200 Logo
331 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
