Question about Kitchen Ranges
KitchenAid Superbra gas range oven won't turn on. All the burners seem to work fine and the panel works fine too. Prior to it not turning on I would smell gas when I would use the oven. I noticed that things took longer to cook. Plz help.
  • Diane McSwine
    Diane McSwine Oct 08, 2009
    There is no gas leak. I have tested it for gas and ensured that all connections were tight. The burners are working fine and no gas smell comes with the use of the burners.
  • 10,515 Answers
As you might have smell gas earlier, and it is not working now, my first bet would be to check Gas Leak. I have seen many cases of gas leak. A small leak may have developed at a pipe or tubing connection or at a fitting in the gas supply line, etc. May be best to contact the propane suppler and get their opinion.
Unless you are handy with tools, confident and sure you can locate the leak within the gas piping/tubing system to the stove. In this case, leak detection soap would need to be used to locate the leak if it's not within or behind a wall, etc.
If all else fails, suggestion is to contact a professional gas plumbing and piping contractor. A gas leak not in an appliance requires specialized skills and electronic leak detection tools. In my opinion, gas leaks are often best left to a professional for your safety and peace of mind.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 08, 2009
  • taran_2005
    taran_2005 Oct 08, 2009
    Thanks for your response!!
    I answered the solution on the information you gave me earlier. However, if you are sure,it's not gas leak, the next step would be :-
    Let me now that this works,
    You may find that if you unplug the
    washer for 5 minutes when you turn it on it will reset the system,or if
    you can not reach the plug, turn off the breaker instead for this
    aloted time and it should work the same!
    Let me know that you have succeeded!
    If you oven uses Electronic Ignition then more than likely this is the problem.
    Faulty Ignitor
    If the oven ignitor gets hot (glows) but oven will not light then it is likely that the itself is faulty.
    This
    seems counter entuative but it is not. The ignitor has a very specific resistance that allows a critical voltage to be supplied from the
    ignitor to the gas valve. If the ignitor has so much as a hairline
    crack, the resistance of the ignitor will increase which in turn will
    decrease the voltage to the gas valve. As a safety feature, this will
    result in the gas valve not being able to open and no ignition will
    take place. The recourse in this case is to replace the ignitor.
    In few case, i have seen Power surge an issue as well.
    Hope i helped you.
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
Gas in oven not turning turning on, only electric works and oven does not heat to required temp. Gas on burners works.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 10, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Aid Gas oven will not turn on
you nee a new ignitor for the bake part of the oven. they are on sale for 20.00 dollars, do it your self, remove bottom plate, and you will see ignitor on back of range attached to gas line.
Sep 22, 2009 | KitchenAid Kitchen Ranges
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
Oven not heating KitchenAid KERC506HWH3
It could be the sensor. Remove the sensor and check for 1 to 1.1K ohms. at room temp. If that's not the problem it may be the oven solenoid on the burner. You can also have a problem with the door lock making when it shouldn't check that also.
Dec 21, 2007 | Kitchen Ranges
KitchenAid superbra range KGST307
I am not a repair man or anything, just an owner with the same gas range slidein appliance. What we have found to work was 1) plug in the probe into the socket in the oven 2) Turn on oven with the probe set at the minimum 160 degrees. and oven temperature to 325 degrees. 3) click start 4) wait for oven to reach probe temperature. 5) oven will then beep show end 6) Click cancel 7) open door and remove probe. 8) wait five minutes before trying to use again. I hope this helps you it has work for us so far. 6)
Aug 27, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
