Question about LG LSC26905TT Side by Side Refrigerator
Water despensing all of a sudden very loud
When getting water from the door and/or ice despenser filling, started getting very loud
    Sergeant:
    Champion:
  • 310 Answers
Needs to defrosted and the filter needs to be changed
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 10, 2008
No water or ice despenses from ice maker...replaced filter....reset replace filter ind., but still no water of ice. It's a side-by-side model MFI2067AEW. Can you help?
i would check for a blocked line,, do u have the water on if so then ur fill valve (where the house water line attaches) may be defective, some models have two depends i would start there, if that is okay then might have a bad im assembly
Apr 09, 2010 | Maytag MFI2568A Side by Side French Door...
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
General electric refridgerator won't despense water in the door
Have the same thing happen a few times. The posted solution is correct, but in the mean time you can thaw the line by heating with a blow dryer inside and outside the door, and around the ice dispenser. This should take about 15 mins.
Jun 03, 2008 | Refrigerators
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Water dispenser starts running when freezer door closed
if you wich to disable the despenser for water in the door just unplug the electrial connector on the water valve it has 2 selenoids on it one is for water in the door it has the largest plastic line under the selenoid
just unplug the connector to that selenoid
you will still have ice and it will despense through the door
Apr 20, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
LG LSC26905TT Side by Side Refrigerator Logo
77 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Mike
Mike
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
