Question about Zenith P42W46X 42 in. Plasma EDTV
My Zenith P42W46X 42 inch tv got two black lines vertical lines on the screen the were coming and going away before but they are more stable now.i opened it up and wiggled all the connections arround the panel but it didn't help,what should i do?
  • Leon Brown
    Leon Brown Mar 28, 2012
    just wanted to say thanks . I solder the chip and all is good
    Problem Solver:
  • 11 Answers
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable near the black lines. Unplug the ribbon cable and look for black chips on the underside of it, I think they say 100 on them, you need to resolder both ends on each chip. Should fix the black line issue.
Posted on Nov 16, 2009
Testimonial: "thank you for your respond.you are absolutely right and i have already done that it is fixed now, thank you for caring and your time,,,:)"
  • Leon Brown
    Leon Brown Jan 21, 2012
    Is , the ribbon replaceable ?
    I have same issue , but just 1 line in center. I have narrowed it down to the center ribbon. I can press on the back of the metal plate an the line goes in and out.. I unscrewed the plate and can see the 4 black chips on it. I don't see any soldering on the chips on the ribbon. Can you explain more about soldering the chips , please?
  • John W Jan 22, 2012
    There should be solder on both sides of the chip. There usually is, but it gets a crack. I would just hit each side with some new solder.
    President:
  • 1,922 Answers
Sounds like you have some defective electrolytic caps in the vertical coupling circuitry
Posted on Oct 08, 2009
Lot of color line vertical on screen
most comun problem is the TCON-BOARD this card fix colors and sharpness on tv
Mar 04, 2014 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X - no picture
if the lines covered the entiire screen, fist I would check to see if the TV's menu can be seen. If not then check the buffer boards. Next I would check the logic board
Jan 09, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Black vertical line 2 in wide on zenith p42w34p
Hello, I can help you fix your plasma TV. If you have Black vertical 1.5 inch line/s that come and go. Please feel to call or message me at 1-503-432-9904 or pleasefixitdave@yahoo.com Ask for Dave! Later guys!
Jan 02, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black verticle line on screen of zenith p42w34
I'm sorry you have not been given a clear answer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave! If your reading this post and you have a plasma or LCD type TV and need any type of help please feel free to give me a ring or message me with the problem your having. I'll do my best to help you!
Talk to you later!
Dave :-)
Nov 30, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Zenith P42W46X 42 inch EDTV
common problems with these, usually customers here a loud pop. then the screen goes blank. I would try...
Some of these have a 4 pin test on the control board that you can jump with solder to get test pattern. If you get it to do that then these boards maybe good and would replace the control board. if nothing happens, then
the upper & lower drive also the Ysus and Zsus boards all at the same time.
last could be a defective panel.
hope this helps. p/n are on all the boards.
Jul 22, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Black bar
On a non H.Def plasma, there is a PCB that runs along the bottom of the screen that is attached to the screen by a several brown/gold colored flat ribbon cables. I've seen where this ribbon cable is not seated properly in the jack. The ribbon cables are generally responsible for that section of the screen. Next possibility is the PCB itself is defective.
Not to scare you, but the plasma screen itself is a possible suspect.
Jun 25, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Black stripe down TV plasma screen
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
Apr 05, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
Oct 03, 2006 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Zenith P42W46X 42 in. Plasma EDTV Logo
1,030 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
