How should I place the tie mic
I'm using a Bardi US880 series mic with a tie clip. when I set it up the sound is very low. If I increase the volume, it feedsback immediately. how best can I set up the tie clip mic.
  • 22 Answers
Typically you want to wear the mic 6 to 8 inches below your chin clipped to the lapel area. It seems in this case it has more to do with EQ and speaker placement. If you can stand behind the speakers while using the mic. The sound bouncing back and forth between the mic and the speaker is what causes feedback. Also try setting the mic channels EQ with the following settings.
Turn Lows down to about 7 to 9 O'clock
Play with Mids to match actual source, but never boost above 12 O'clock
Keep highs around 10 O'clock (boosting highs increses chances of feedback.) If to muddy sounding keep highs aroun 12 but not over.
Good Luck
Posted on Oct 09, 2009
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
When I FaceTime someone I can hear them but they can't hear me well
I can't hear you, lol
First thing is to rt click on the little speaker icon on the rt side bottom corner, then click on open volume mixer and increase the mic volume.
Try going to control panel and open the sound setting, look for mic settings and increase the mic volume.
Apr 10, 2013 | Photography
Mic input is always to low to hear but can see on slide gage. Last try said it was "being used by another device". ???
Right click on the volume control and open the volume controls mixer. If the mic volume is not shown choose properties and there you can add it. You will see a tab called "advanced". If you open that you will have a check box that allows you to turn on or off a setting that will increase the volume of the mic by 4db. IF it is being by another device, evaluate clearly what software you have open at the time. Close them a get to the basics of getting the volume up. It is an attenuator setting for the mic input.
Mar 08, 2013 | Biostar MCP6P M2+ Motherboard
Can you please tell me how to increase the volume on my husbands phone as it not very loud thank you
most of the times there are side keys in mobile placed on either side of the mobile by pressing them up and down we can increase the volume. but if a pair of keys is not present on one you are talking about then certainly in setting-----sound settings you can increase the volume of the mobile. but keep in mind some time if a mobile previously working fine suddenly started to transmit low sound there may be a problem in mic as well. try the above mentioned steps and if the problem remains focus on the mic. it may be replaced by some mobile repairer.
Also it may be possible that the output sound of your mobile is low as you listen from your own mobile its volume if increased could also give you good results. thankx
Feb 10, 2011 | Cell Phones
When im recording,the voice is to low
DEAR SIR,
R U USING LINE IN OR MIC , IF MIC , INCREASE MIC VOLUME FROM VOLUME CONTROL PANEL, & IF U R USING LINE IN INCREASE VOLUME OF LINE IN FROM CONTROL PANEL ..
Jan 05, 2011 | Computers & Internet
HP pavilion dv9005us. When using built in mic receivers say volume is very low. When I move the lid I get a crackling sound in the speakers like the mic wires a lose ..
To fix the low volume problem in mic receiver follow the steps below:
  1. Click Start , Control Panel .
  2. In the left panel, select Classic View .
  3. Select Sound , and then select the Recording tab.
  4. Right-click on Microphone and select Properties .
  5. On the Custom tab, select Microphone Boost .
  6. On the Levels tab, increase the microphone recording volume to the maximum level.
Then please check if it works fine otherwise you need to install the latest sound driver.
Windows VISTA 64bit and 32 bitsound driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35684.exe
Windows XP sound driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Install the sound driver as per your operating system.
Apr 04, 2010 | HP Computers & Internet
I can hear other people but when i speak they cant hear me
The problem is with the mic you can verify it with by trying to record the sound using the sound recorder application. if you not able to record the sound.check whether mic is detected and it is not muted .sometimes mic may be muted.increase the volume of the mic by clicking the sound control option.
Mar 03, 2010 | Apevia Laptop Keyboard for Acer Aspire...
Microphone volume goes down automatically
Go to control panel and select the sound option
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Cheers
Jul 08, 2009 | HP Pavilion dv6000z Notebook
I just got new laptop has vista home premium i can't get voice in yahoo messenger.
Voice may not be available due to several reasons
sound card drivers
Mic volume may be low in the sound settings in control panel
Try looking for mic volume and increase it...
Aug 01, 2008 | Computers & Internet
128 people viewed this question
 Grubhead
Grubhead
