Question about Tascam MD-350 Advanced MiniDisc Recorder
Getting a rec error message whilst trying to eject mini disc
I have just solved the problem get a small flat head screw driver and whilst ejecting put it into the hole where the mini disk goes. now when i say gentle i mean gentle GENTLY feel for the edge of the mini disk you will find it. When you know you have found it very gently and slowly push the mini disk up and down and the disk will pop out you wont damage anything as long as you are slow and gentle. If it doesnt happen first time dont worry it will with patience but dont be heavy with it. The problem is the disk and not the player. you have a corrupt disk which is quiet common. Just throw the disk away. Turn the machine off for 10 seconds and turn back on put another disk in that your not bothered about and you will see that it shoudl play etc try recording onto that disk and you shoudl see that the player is working fine
hope this helps
Posted on Feb 11, 2010
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Apr 01, 2013 | Sony MDS-JE330 Mini Disc Player
RTs00c00e00 ERROR MESSAGE, WILL NOT PLAY TURN OFF OR EJECT. TRIED TURNING POWER OFF AND UNPLUGGING, SAME ERROR MESSAGE COMES UP. PLEASE HELP! NOT IN MANUAL.
I just turned on my Sony MDS-JE520 and got the same error message RTs00c00e00. Didn't wanted to play MD, but did throw out the MD. After turning it on and off still got the same message. When I took the remote and pressed the key display, it came back to the normal "mode". Everything works again, so hopefully it stays with only this one-time incident.
Hope it will help you guys also.
Regards, Danny
Nov 23, 2009 | Sony MDS-JE330 Mini Disc Player
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Eject disc and turn off console
unfortanatly your right sent that to nintendo it has to be a factory malfunction
Nov 09, 2009 | Nintendo Wii Console
Sony minidisc MDS-JE530 c13 rec error
This could be a solution for your problem, if you get a C13 error it's because of dust on the lens causing TOC read errors. Try blowing out dust using clean compressed air (the kind in the can used for computer maintenance).
Aug 02, 2009 | Sony MDS-JE330 Mini Disc Player
C 13:02 dvd-rw mini disc errors
It's not recommended to format a disc in the Computer and use it in the Camcorder.
It seems that there is an issue with the disc.
The disc should be formatted within the Camcorder itself.
I will forward a link to a page where you can get the information regarding the error message appearing on the LCD screen of the Camcorder.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C79466
May 15, 2009 | Sony Cameras
Mini Disc Not Working
Pull the power cord. Make sure the three-position switch with "REC/Standby/PLAY" is in the middle position, then plug the cord back in. Wait a minute, then press POWER. Now load a disk and wait 1 minute for it to read the Table of Contents (TOC). Either it will show the tracks, or it will say 'empty disk'. Let us know what happens from there, okay?
Oct 06, 2008 | Sony MDS-JE480 Mini Disc Player
Eject disc, power off, error message
I would just send it back, especially if it for free. I wouldnt tamper with it at all.
May 04, 2008 | Nintendo Wii Console
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Tascam MD-350 Advanced MiniDisc Recorder Logo
193 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
