The Fault fuzer. Possible faults of the block of the fastening the scene or in contact of the join or in signal of the controller of the direct current. Address please in service Sharp
H2
00
Fusing unit temperature error
01
H3
00
Overheated fusing unit
01
H4
00
The fusing unit doesn't heat up
01
H5
01
Papersensordefective in the fusing unit
02
Comments:
Oct 08, 2009
- H - a fault of the node of the fastening. The Repair fuser is not simple. Will Take adjusting the temperature of the block or change the lamp of the heating. This work for prepared personnel and requires exact adjustment and analysis. Also adjustments for repair and exact service documents. Recommend You to call in service for skilled repair. Good luck.
sharp arm350-450 the imagistics versions adjusting of the printer void area lead & trail edge...
(More)
sharp arm350-450 the imagistics versions adjusting of the printer void area lead & trail edge voids, the book & updates void prosedues do not work?
SIr, I have the SHARP AR 5320E photocopier. How can i set the password to avoid the unauthorised...
(More)
SIr, I have the SHARP AR 5320E photocopier. How can i set the password to avoid the unauthorised users. thanks in advance...
