Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum
Problem for Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic...
Hoover U8147-900 WindTunnel V2 Bagless Upright has
By spl127236 on Oct 08, 2009
Hoover U8147-900 WindTunnel V2 Bagless Upright has sparks coming from motor housing
Solution #1
posted on Oct 08, 2009
Not Rated)
Chemist1961
Rank: Guru  Vacuums  Expert
Rating: 93%, 131 votes
Most bagless uprights are exposed to dirt being drawn through their motors and filtered afterwards. As a result when you see sparks the motor has generally suffered its final breath... Today's uprights often run with high RPM disposable motors where older bag type uprights used lower speed rebuildable motors.
So the short answer is you likely need an entire motor as a minimum. If the unit is a higher end model mover $200 , in great condition and less than 5 years old, take it to a Hoover service center and either buy and install a motor or have them rebuild it. But also consider this...
What most people don't realize is they spend more on high priced consumable filters for many cheap bagless vacs than they ever would spend on bags and in the end the bagless is dirty to handle and has a shorter life span. Mass merchants sell the vacs cheap because their profit is in the filters
Remember a vacuum is the hardest working appliance in your home in the toughest possible conditions
If you replace this vac do so at a pro shop and see the options they have. You will get good advice , you will spend a bit more with better results and less frustration because you will build a relationship .....and always know where to go for service.
Was this helpful?
Yes
No
Popular Solutions for Hoover U8147-900 WindTunnel V2
Questions and Unsolved Problems for Hoover U8147-900 WindTunnel V2
Do you recommend Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum?
Answer
Answer
around the canister when the vacuum is in operstion it blows out dust on the sides of the canister
Answer
My hoover windtunnel 2 has a 'self cleaning' hepa filter. It does not spin at all and it clogs with... (More)
Answer
hoover steamvac trigger valve is stuck open. water keeps coming out with trigger released. How do... (More)
Answer
vacuum cleaner started blowing out dirt and then motor sounded much louder . I cleaned machine... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover U8147-900 WindTunnel V2...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
