Question about HTC Touch Cruise Smartphone
Any help would be greatly appreciated, willing to start from beginning, any gps/satnav will do if can get instructions
    President:
  • 1,884 Answers
With this phone you get only one city's map. rest you have to buy. However, you can use google maps from www.google.com/maps. Plenty of features like Latitude and Layers. Download from google site, free.
Posted on Oct 08, 2009
Testimonial: "thanks, i shall try google maps Regards "
  • Vinay Tevatia
    Vinay Tevatia Oct 08, 2009
    Thanks pal. With google latitude you can keep track of your friends who too have to use latitude as they can keep track of your movements. good feature unless you do not want your spouse to know where you are, in which case you can even give misinformation. Think about it.
How will you charge a gps nuvii garmin 1450 using computer?
To charge a garmin nuvi gps with your computer you connect your satnav to the computer's usb port using a mini USB lead. Turn on the computer and the satnav and the satnav will begin to charge. It will take approx 8 hours to charge compared to 4 using a car charger or mains charger.
Feb 05, 2011 | GPS
I am trying to download the Mexico 2011 map and the download stops because it states I do not have enough space. They advised a 4 GB SD chip which I purchased and installed. The download still stops and it...
When you go to download the map by default it tries to download it to the satnav i.e. not the SD card. When the website recognises the satnav it shows it in a drop box with a drop-down arrow. Click the drop-down arrow and it should give you the option to download the map to your computer. Download it to the hard drive.
After it's downloaded it may begin the install automatically. If not click the START button on your computer and go to GARMIN. In the garmin menu click MAPINSTALL to begin the installation.
When the install program finds your satnav and you get the option to install the map there again click on the drop-down arrow and select the drive letter of the SD card. This will be different to the drive letter for your satnav. The map will then be installed to your SD card.
Before you begin to install to the SD card you should know that it can be very hard to get get the 200W, and other satnavs of the same age, to run the map from SD cards. It will install to it without problem but when you try to operate the satnav then it cannot load the map and will close down again unless you remove the SD card. I recently had this problem with a garmin nuvi 760 and contacted garmin about it. They told me the problem is that 4 Gb SD cards are SDHC which operate differently from SD. They said to get a class 2 SDHC card. (You can identify the class by the small figure on the card. It will be either 2, 4, 6, 8, or 10). Before you install the map format the card. Also use webinstaller to check that you have the latest version of operating software on your satnav.
Format the SD card with "Panasonic SD Formatter" available from http://panasonic.jp/support/global/cs/sd/download/sd_formatter20.html
rather than the standard windows format function. Select the fast format option and be sure you have selected the drive letter of your SDHC card as it will format your hard drive just as easily if you select it by accident or your satnav.
To update your software you can download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Connect your satnav to the computer and run the program. It will search for any updates to your software.
Class 2 SDHC cards are available on ebay if you can't find one in the shops.
After failing to get mine to work on a class 4 SDHC 4Gb card I followed their instructions and it worked for me. Hope it works for you too.
Oct 27, 2010 | Garmin nuvi 200W GPS Receiver
Can i have step bt step images of how to insert my new sat nav into my car?
There's a manual for your satnav at http://static.garmincdn.com/pumac/2675_OwnersManual.pdf
Page 2 of the manual gives instructions for installing your satnav complete with pictures.
Oct 12, 2010 | Garmin nuvi 255W GPS Receiver
No voice
First ensure that the mute box is not ticked on the volume setting screen. If it's not then follow the instructions below.
Press tools, settings, language and press voice. Select a voice from those available. It's possible that the voice file is corrupted. If this is the case connect your satnav to your computer. Download and install webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 This will search for updates for your satnav. When it's finished updating software it will give you the option to download voices. Click on the ones you want and follow the prompts. After you have disconnected the satnav from your computer you'll need to select a voice on the satnav again as described above.
Aug 08, 2010 | Garmin nuvi 205W GPS Receiver
Operating manual for navman f10,GPS
You can download the same from :-
http://safemanuals.com/user-guide-instructions-owner-manual/NAVMAN/F10-_E
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 28, 2009 | Navman GPS
Pin570 using garmin Mobile XT software,GPS not working
Try Start Settings System GPS and tap ON before starting the satnav program. Not all programs automatically switch on the GPS. On hitting ON yellow light top left starts flashing. Now start your satnav program..
Aug 08, 2009 | Navman PiN 570 GPS Receiver
Satnav Problem
I purchased this sat nav only a couple of weeks ago :@
and when i punch in a post code for it to take me to the place i want to go it shows me the wrong way and it switches off on it own this is really irreating and im pissed off so anyone know what to do then i would be greatful from -- Jordon Carrter :)
May 18, 2008 | Garmin StreetPilot c510 Deluxe GPS...
HTC Touch Cruise Smartphone Logo
83 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
