Question about Verbatim SmartDisk Firelite Portable USB 2.0 250GB GO 5400 rpm/tpm 250 GB Hard Drive
Hi I mistakenly bought a Smartdisk Firelite with a FireWire connection. On my SONY laptop I only have USB ports. Can I purchase an adaptor so that I can make use of the portable hard drive? Hope you can help - an expensive mistake on my part!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Sure can - and cheap to! Here you go for a link to eBay site with them...
Please vote kindly if this was helpful
Posted on Oct 08, 2009
Testimonial: "Thank you so much - can't believe how fantastic this response is!"
Firelite smartdisk does not mount on my Mac
Your drive may be in NTFS file format that is not supported natively by your mac, try looking for NTFS support or reformat your drive to FAT32.
May 02, 2012 | SmartDisk CrossFire Desktop FireWire/USB...
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
Trying to connect my old Smartdisk USBFLB120 to my Toshiba Laptop with Windows 7 64 bit - can't get drive to recognize as drive - Lapop sees device but says it is unavailable
Change you usb port or replace the smartdisk's usb cable, probably the current one if broken. Also restart the pc whilst the smartdisk is connected. It shd be recognised now.
Jun 06, 2011 | SmartDisk FireLite USBFLB120 120 GB USB...
I have a Firelite Smartdisk External 60G hard drive - Model #FWFL60-N which I bought to back up my previous MacBook. It only has FireWire outlets and cable with only FireWire ends - no USB port...
Hi Selina It was a big mistake for Apple to omit the FW port on the white MacBook. The problem you hilite is the reason I don't recommentd the macbook to any of my clients. However, the problem is solveable - although you may/will have to do some breaking and entering.
There is no cable adaptor - nor will there ever be, the protocols are so radically different that they can never talk to each other.
The simplest option is to connect your drive to another mac that has got FW (800 or 400 - it doesn't matter as long as the cable will connect the two units) then use file sharing to transfer the conent of the drive to you MacBook either by ethernet (preferable) or by wifi (much slower).
The breaking and entereing option imvolves opening up the firelilte and removing its HD (it's easy) then get a unit like this Overview or this http://www.maplin.co.uk/sata-hard-drive-usb-docking-station-222999
There are other much cheaper units and they all work fairly well. I have several as I'm up against your problem regularly
Apr 01, 2011 | Computers & Internet
I would like to remove all the old data from my Smartdisk usb flb160. How do I do that
Connect the SmartDisk.
Open "My Computer".
Right-mouse click on the icon for the SmartDisk.
Click FORMAT
Click 'OK' to completely "empty" the disk-drive.
Nov 13, 2010 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Jul 05, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
My firelite smartdisk model cord does not fit into my new macbook air. can i buy a cord that has a usb port at one end? thx
The MacBook Air has one USB port. Most computer stores have many different plugs on the other end that will fit your SmartDisk. Most of the SmartDisk units use the mini USB plug. It is the same as many digital cameras use.
Tiger Direct, and MicroCenter also have many different adapters, and adapter kits to use on all kinds of USB devices.
I hope this helps. Please let me know if there are any more questions.
AAirwolf
PS: I use a 160GB SmartDisk on all of my Macs, and PCs. Get way to move data without conflicts.
Feb 13, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
USB Device Not Recognized...
try to the laptop firewire port, if works. I didnt find any support for youfirelite drive
Dec 29, 2009 | SmartDisk FireLite 40 GB Hard Drive
My smartdisk firelite does not appear anywhere on my computer
Sounds like you have a hardware failure either in the drive enclosure or the hard drive itself.
I suspect you may get lucky and find out it's just some of the circuitry in the smartdisk shell that is damaged.
Take the Smartdisk unit to your nearest PC shop and ask the technicians there to remove the Hard Drive and put it in a new enclosure to test it. If it works in the new enclosure, buy the enclosure and your done. If it doesn't work in the new enclosure then you may be suffering from worse issues that will require the help of a pro.
Either way let me know how you make out, if you need a pro for the next step, reply back with you location(Country, State, City) and I will refer you to the closest facility who can assist you.
Hope this Helps FixYa,
Chris
Aug 17, 2009 | SmartDisk FireLite 60 GB Hard Drive
Verbatim SmartDisk Firelite Portable USB 2.0 250GB GO 5400 rpm/tpm 250 GB Hard Drive Logo
242 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
