Question about HP PSC 1350 All-In-One Thermal Printer
Vertical inky mark about one inch wide after changing both cartridges covering whole length of paper
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Run a few pieces of paper through - it should disappear fairly quickly... it is because some ink got on the roller which pulls the paper through...
At worst open the machine a clean the roller with a damp cloth and wait a few minutes until it dries before using.
please vote kindly if this helped
Posted on Oct 08, 2009
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
Apr 02, 2011 | Brother MFC 6800 All-In-One Laser Printer
I have an HP LaserJet1020 printer. When I try to print a document a 2 inch wide area the full length of the page on the right side of the page) will not print. If I change to landscape printing, the same...
Run the 1/2 print test.
Print a few pages that have failed previously and as the printer is printing open the cartridge cover(top cover).
Pull out the cartridge and look at the paper down below. If the page looks good, you probably need a new fuser. If the page is messed up you could have a bad transfer roller or another bad toner cartridge.
Dec 19, 2010 | HP Office Equipment & Supplies
All printouts have a 3/8 inch wide light vertical line -
Try an old toner cartridge if you have one. Does it do it when you use the copier function. Steven 805-520-3003
May 12, 2010 | Brother MFC 9700 All-In-One Laser Printer
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
Printout has a smudge or streak about an inch wide, full length of paper about 0.5 inch from left side.
You need to change toner cartridge for new one.
Most problems of quolity from it.
If is not help you, it may be broken termo fuser - go to service.
Dec 17, 2009 | HP LaserJet 1200 Printer
White vertical line on pages from brother mfc-7420 printer
Do a half print test......send a print job to the printer listen to the printer...as soon as you think the printer has printed a bit of doc inside the printer..not reaching the fusser ......turn off the printer
Remove the cartridge.....and watch the print inside on the paper can you see the marks.....if so than its your cartridge that is marking your print....
remove the paper by slowly pulling it be careful not to tear it
If the print hadn't been marked on half test.....remove the fusser unit and examine the Teflon cover for marks....try to remove stains off if there is.....avoid marking the Teflon as this will mark more on the print
do advise if this worked if not than you have some more options
Cheers!
Nov 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
Black strip over all printed papers
Check your Drum cartridge, if you see your strip replace it....If it's not the problem you may have a bad Fuser ....
Mar 25, 2008 | HP LaserJet 1100 Printer
Faint Black Lines
Hi best way to check is to remove the black photoconductor and you should be able to see the little lines on it also check the the black dev/toner unit for the lines. most likely to be the black photoconductor unit though.
Thanks J
Jan 24, 2008 | Ricoh Aficio CL3500N Laser Printer
Minola print smudge
Pleas check the imagine unit drum, is it clean or does there are the same marks as in paper.
if yes, the IU drum cleaning or drum itself is damaged and needs to be replaced.
Try:
after sending a print job, when printer has take a paper from tray, open cover, open cover before the paper enter the fusing unit, then you can see, if the mark is allready in the paper then the problem is in the IU or toner cartridge, if not, then fusing unit rollers.
Dec 31, 2007 | Konica Minolta magicolor 2400 Laser...
HP PSC 1350 All-In-One Thermal Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
