Question about Dell Vostro 1510 Laptop
Change hard disc problem
I try to install window xp and can copy files i changed the hard disk and install window xp the pc could not start up It is not strart even from bootable disc It says there recent hardware or software change
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Ah this is a nightmare problem.... the only solution I know of to fix this is tiresome to say the least
Reinstall XP
But you need to delete the partition that Windows is on
and then reboot your computer
Go back to install XP and all should work well -- you may need to remake the partition and format it before Windows recognises the disk - but that is simple enough
If you can not boot into the CD - you will need to change your BIOS settings to boot from CD first
When your computer comes on a screen displays
It will tell you which key to press to get to your BIOS setup / settings page
Look for boot options and make sure the CD is first on the list
That will get things working -- a total drag I know but it is the only way I have found of getting this to work
Please vote kindly if this has helped
Posted on Oct 08, 2009
Can i remove a pirate copy of windows 7 and replace it with my genuine copy of windows xp
you would need to insert to XP disc in the cd drive and reboot the pc. As the pc reboot whatch for "Press any key to boot from disk". This will make the pc bypass the hard drive and load the boot file from the XP disk. Once you have answered the inital start questions, it will give the option to format the hard drive or create an extended drive. If Win 7 is not needed any more, I strongly suggest doing the format and have a fresh, new install of XP, Genuine copy.
Good luck.
N.I.T.
Jun 14, 2014 | Microsoft Office Professional 2007 Full...
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
Missing or corrupt hal.dll file, so can't boot the hard drive
Hey,
Please use the recovery discs or windows installation cd.
To either perform a full system restore with the recovery discs.
Or to perform a repair installation with the windows installation cd.
Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter to start the Windows Setup. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Thanks and good luck.
Ekse
May 03, 2009 | Dell Dimension 3100 PC Desktop
Needed to reinstall xp home-sp2 with my recovery cd-rom
Try changing the CD, if that dosn't solve the problem :
1. Format the whole hard disk using the default partition manager.
2. Install XP freshly.
Mar 13, 2009 | Microsoft Windows XP Home Edition
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
Installing
The game was released back in 2002, that means it was designed for older versions of Windows OS (Windows 98/ME/XP). The updates for the game do not have any patches for the installation to be compatible to the new Windows Vista OS as they were released on November, 21st 2002 aslo that patches resolve functionality issues after the game is successfully installed.
Some game ".exe" file (executeable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Oct 12, 2008 | ValuSoft Hard Truck: 18 Wheels of Steel...
Install
This solution is not for the XBOX version of the game, this is only for the PC version of the game Bard's Tale.
You can still try to make the game compatible for installing it on the Windows XP 64 bit by following the steps below.
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP" and then click on "Apply".
The same set of Compatibility steps can be used for installation of older games installation on Windows XP 64 bit and Windows Vista.
Again, this solution is not for the XBOX version of the game.
Sep 06, 2008 | Vivendi Universal Bards Tale: Song of the...
Window currupt
1- the problem is a software problem your board and processor are ok.
2- the message you saw indicates curruption in the windows files its strongly recomended that you install a new copy of windows even if the erors could be recovered..
reformating your hard disk is necessary to reinstall a new coppy of windows.
May 27, 2008 | Intel Motherboard
Dell Vostro 1510 Laptop Logo
63 people viewed this question
Alun Cox
