Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
HOTPOINT WASHING MACHINE - BELT IS RUBBING AGAINST BACK OF DRUM & WEARING BELT + INTO PLASTIC DRUM CASING. I HAVE TRIED MOVING THE BELT TO THE FRONT EDGE OF THE MOTOR PULLEY DRIVE, BUT AFTER A FEW SPINS, IT JUST CREAPS TO THE VERY BACK ON THE DRUM WHEEL AND RUBS AGAINST THE BACK OF THE DRUM? THERE DOES NOT SEEM ANY ADJUSTMENT FOR THE ALIGNMENT OF THE DRUM WHEEL OR THE MOTOR DRIVE POSITION? ANY IDEAS PLEASE?
    President:
  • 1,304 Answers
If you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
Posted on Oct 08, 2009
Hoover washing machine very noisy on spin cycle, removed the back panel and black sooty deposits on rear of drum
when you open the back did you check if belt has jump out (as they are grooved) or is wearing out, any other rubbing surface rubbing around, locate where the black sooty is coming from and i might be able to find the right answer.
Aug 09, 2013 | Hoover Washing Machines
It started making a terrible noise when spinning then when it finished the drum inside would hardly spin round when pushed by hand then i took top of and noticed belt at back was off so i struggled putting...
The drum bearing has very likely failed and seized.
If the outer drum is polypropylene (plastic) then the bearing cannot realistically be replaced and the entire drum assembly needs changing. This is not usually cost effective unless you can find a suitable used donor drum from another broken machine. Even then, it's usually better to use your machine to donate the parts needed by the other unit.
If the outer drum is steel then the bearing can be replaced if you can get the spare part, but the drum must be completely removed to do so and it's a major job. The old bearing needs to be drifted out (I use a short off-cut of scaffold pole) and the new one needs drifting back in. (Drifting means using a heavy hammer and a suitable object or "drift" to place against the item and spread the load evenly. The hammer hits the drift, not the work item). If you have to drill out spot welds in the washing machine casing to separate the outer panels in order to remove the drum (common) then you can use pop rivets afterwards to reassemble it. Note that you will probably need to replace the drive belt as well, but try using the old one first unless it's clearly been damaged.
Bearing replacement is a major job and due to the extensive labour costs and risks of the job failing a professional usually just changes the entire drum assembly, but anyone good with car repairs should have the tools and experience necessary to do this on a DIY basis. The bearing itself is usually quite cheap and if Hotpoint can't supply it you should be able to take the old one to a specialist bearing shop and obtain a direct equivalent.
Good luck and please take a moment to rate my reply.
Sep 22, 2010 | Hotpoint Washing Machines
Bra wire stuck between the drums in hotpoint WD440 Aquarius washer dryer
Look all around the inner tub with a torch , if you spot the wire sticking through grasp it firmly with pliers and pull out , dont let it go , if it slips completely between drums it is more difficult to get to.
Nov 08, 2009 | Hotpoint Aquarius WD63 Front Load...
During the spin cycle basket vibrates very badly - very rough
I had a similar problem. During the final high spin and there was POW and the drum went funky eating into the plastic. I opened the back of the washer and look things over,.The belt for spinning was intact. I set the washer on a drain/spin option and watched from the front and back. While watching the pulley on the drum and could tell there was a hiccup as it went around. I pulled the pulley off and put on a new pulley. The new pulley was going in a perfect circle to spin the drum. It's not a hard repair, just need a little muscle to loosen the nut holding the pulley on and the same muscle to tighten the nut as much as possible. Hope this helps.
Nov 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Very noisy and moving around Hotpoint washing machine
there are four shipping bolts in the back of the washer that need to be removed they are long bolts connected to plastic pieces. unscrew them and remove the plastic pieces
Oct 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | GE WJSE3110A Top Load Washer
How do i change the brushes on my wf250 hotpoint aquarius machine
your machine may have a 'brushless' motor. but generally hotpoint motor brushes are fixed with 2 screws and are in ablack plastic cover and can be seen if you tip your machine back against a wall and look underneath. the motor being at the bottom of the drum, you could remove them wuth a long magnetic screwdriver.
Feb 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WM31 Washing Machine
The tripping can either be down to a short circuit drawing too much current and blowing the fuse , or an earth leakage blowing an RCD. You can eliminate the motor when it happen again , by unplugging it and see if the fuse blows (without turning the drum). Most likely is the heater , but i cannot explain why turning the drum allows it to continue. It is possible a wire is rubbing somewhere on the drum pulley , motor or casing. If the machine will immediately trip again if you don't move the drum , try isolating parts by disconnecting and then retrying.
Aug 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius drive belt wont go on
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Feb 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
284 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
