Question about Toshiba 55H70 55" Rear Projection Television
Double Image Turned it off last night it was fine. Turned it on this morning and problem was there. What happened and how can I fix it. TV is much too big to try to take to a repair center. Thank you,
    President:
  • 4,402 Answers
Sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 25, 2007
My Hitecker 32 inch TV suddenly will not show any inputs other than TV. Worked fine last night. Doesn't this morning. No power surges that are known about overnight.
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 01, 2014 | Televison & Video
Tv lcd slow dark image
Sounds like a fault with inverter. What lamp have you replaced?
Dec 26, 2013 | Samsung Televison & Video
Last night the tv was fine i turned it on this
Unplug 20 minutes. Make sure there is adequate ventilation around the set.
Try with the original manufacturer remote to view setup menu.
Power outages come at night. This sometimes resets the TV and other devices. .
Mar 25, 2010 | Insignia 42" LCD Flat-Panel HDTV
No sound from any source from speakers
check your connections again and ensure you have the audio going out. With many tv's you need to change a setting in the menu, double check that as well.
May 05, 2009 | Denon AVR-687
Black 3" vertical line through the center of my Plasma TV
Sounds to me like one of the drivers for the display died. Typically this requires a replacement of the entire panel (expensive) but I'd check with your local repair shop
May 04, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
CRT TV Screen Colors Off
The tv needs degaussing (demagnetizing) unplugg the set tonight and then plug it and turn it on in the morning. You should hear a a "bonk" noise when the set is first turned on after being cold- this is the internal degausse circuit working and it should fix your problem if you don't hear the "bonk" sound or it does not fix your problem call arepair shop to have the degausse your set and possibly fix the internal degausse circuit.
Dec 23, 2008 | Panasonic CT-32HX42 32" TV
Samsung lcd tv wont turn on
My Samsung LCD 32" 540 has two screens side by side. It worked fine last night, turned it on this morning and now double vision.
Aug 17, 2008 | Televison & Video
Screen appears curved on top and bottom
One or more colors can't be adjusted when when using the convergence menu. Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 22, 2008 | Philips 55PW9363 55" Rear Projection...
Double image - not covergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 21, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
116 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
