Question about Drills
My drill press is going reverse cant find switch to change it back to forward ? just put new cord on could this be problem wrong wiring?
    Brigadier General:
  • 4,090 Answers
Yes you have reversed the polarity
Posted on Oct 08, 2009
What part of the forward and reverse switch is loose on a B&D corded drill Dr560.
What to do next, find your receipt and take it back to where you purchased it and get another one. Make sure the new one works right before you leave the desk of store.
Nov 27, 2017 | Cars & Trucks
Replaced the wiring, and now it has two reverse speeds, and you have to hold it to go forward ..HELP!
both switches are connected wrong,switch the connectors and put it back together,if you need a new wiring harness i have one
Jun 20, 2015 | Polaris Trail Boss
How to wiring the power cord to the F/R switch?
Will need more information: make, model, etc. A corded drill motor can be AC or DC. It can be variable speed on not. An AC motor can be reversed by changing the magnetic polarity of the start winding (switching the two start winding wires). This type of wiring in not usually variable speed. A DC motor is reversed by changing the electrical polarity of the primary motor leads. Usually these type of devices have a rectifier circuit to produce DC voltage and use a PWM signal to develop variable speed.
Sep 24, 2014 | Drills
Will not go in forward only in reverse.
check to make sure that the cables are not binding when mounted causing them to break connection
Jul 05, 2017 | Peg Perego John Deere Farm Tractor and...
Turns the wrong way
sounds like you fixed the plug or cord and reversed the wiring or you just have it in reverse its a switch on it ha ha
Aug 07, 2011 | Makita & 1/2 Inch Drill
Model# 315.114110 (3/8 hammer drill with cord), It only goes reverse but not forward. Is this problem with the trigger or chuck. Thanks in advance.
Sounds like the switch.
Get a hold of sears to see if you can get a new switch from the appliance department.
If not I would re wire the thing so it would at least run forward.
Dec 02, 2010 | Craftsman Drills
No reverse on drill.
I am assuming the new switch was wired correctly, I would look for the pin or similar device that switches it from for/rev. If your switch has a post look at the slider and make sure not broke or your pin not put in rightt position. Let me know
Apr 22, 2010 | Black & Decker Drills
Panasonic EY7540 impact driver. Does not go into reverse on 1st
The forward/ reverse switch is hanging up and the rotation of the drill is switching it, then it changes direction. The switch needs a little TLC and a good cleaning. Blow it out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 26, 2009 | Panasonic Cordless 12V Compact Impact...
Replacing a power cord for a Dewalt electric drill
some of the dewalt drill switches have a one way trap (like) for the wire. you push the wire in and the harder you pull it gets tight on its self. your wires go in the bottom of the trigger look right on top of each wire there is a small **** (no bigger then 3/16) for a flat head screw drive. In the **** you will see a small lever, it needs to be turned at the same time pull. It will help to have a friend.
Mar 25, 2009 | Dewalt Drills
Bosch psb 600 drill will not reverse
The red button sits on a lever that changes the polarity of the switch output. If this lever feels loose and you can't feel it engaging anything then you need to split the housing and make sure it is seated properly. If it is, and the lever on the switch is moving fine aswell then you should check all the wires coming out of the switch, and if they are all connected properly you will prob need a new switch.
Oct 18, 2008 | Bosch Drills
Drills Logo
190 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
