Error message in my yahoo messenger... The password you entered is incorrect. Click ''Try again'' to re-enter it, or click ''Sign-in Problems ?'' if you have forgotten your ID or password. (81003002)... i already change my password for how many times, but still the same problem appears. i already change my y.m. version also for how many times. what shall i do now...? thank you so much & more power...
  • 107 Answers
Reinstall your YM delete all foldres of YAhoo on your program files, download a clean YM installer, if nothing happens, check for virus
Posted on Oct 08, 2009
When i'm entering the yahoo mail and password it takes few minutes then . the message display that there is an error with internet connection though its connected actually .when i try to solve the...
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reginout to fix the issue
Feb 10, 2011 | Yahoo Messenger
When i try to login or run i get error message oxc150002
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." 2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window. 3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. 4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reg in out to fix the issue
Sep 28, 2010 | Yahoo Messenger
I kept having the same problems with YM. Every time i tried to sign in, it won't let me sign in. it's about yahoo! messenger troubleshooter and It said " We can't let you sign in". I am sure it was not...
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button. use registry cleaner reg in out to solve registry error for messenger
Sep 13, 2010 | Yahoo Messenger
I tried to download the lastest yahoo messenger and now I can't even access the old verison. What could be my problem?
Your Yahoo! Messenger connection information may be incorrect. Follow these steps to configure your connection:
If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct.
May 14, 2010 | Yahoo Messenger
I cannot connect to yahoo messenger, it says, there was a problem signing you in to Yahoo Messenger Please click "try again" to re-enter your ID and password, if you have forgotten your ID or password,...
May be ur entering wrong password or id.....click on forgotten password....if u remeber ur correct mail id enter ur mail id....or u can answer the two questions and enter your date of birth.....if u enter it correctly it will let u change ur password n u can agin login using new password......hope this helps....
Mar 10, 2010 | Yahoo Messenger
Cannot sign-in in yahoo messenger
hello, you have to click on that password recovery botton and enter your security question and anwser so they can reset your password for you
Nov 09, 2009 | Yahoo Messenger
81003002
If you are sure you have the correct password, I would start with changing your user name that you are signing in with. Sometimes yahoo seems to want the "@yahoo.com" with the user name, and sometimes it does not.
If adding or removing the "@yahoo.com" part of the user name doesn't help, go through the "forgotten user name and password" steps.
Oct 07, 2009 | Yahoo Messenger
Yahoo can be a pain. Do you have another browser you can use and see if you get a better result> Ive found that sometimes I get password problems with Firefox and OPera so I then use IE to rectify my problems. Are you sure that you are using capital letters/lowerccase where needed?
Oct 03, 2009 | Yahoo Messenger
I can't log in to yahoo messenger
this time your YM is ok... click file or sign-in and find preferences and choose your into your designated internet provide, example dial-up, broadband, ISP,, just choose... no need to uninstall...
Jun 16, 2009 | Yahoo Mail
I can't signing into yahoo messenger
It may be the server is down, it's been happening a lot lately or your Yahoo! Messenger connection information may be incorrect. Yahoo! will fix it soon. To configure your connection, what you should do? Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "Firewall with no proxies" option. Select the correct Internet connection type and country from the pull-down menus. Click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps: Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "No network detection" option and then click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps: Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "Use proxies" option. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings. Click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct. Hope it was helpful!
Jun 09, 2009 | Yahoo Messenger
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
