Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Posted on Dec 24, 2007
Lens error My Casio ex-z60 camara lens wont fully extend.When power is turned on, a clicking noise is heard. The LCD displays what will be captured, but is is blury. Then the lens closes and a "lens error" message apears on the LCD. Sometimes a message that says "retry power on" appears. Every thing else works fine. I am able to view my pictures .but I can not take any pictures.. Thank you
  • 1 more comment
  • lhyphenl Dec 26, 2007
    I had nearly the same thing happen to me yesterday. I turned the camera on while holding it so the lens would extend upwards to show someone how thin the camera is, and that the lens still extends pretty far. When the lens reached full length, it started making noises like the motor was moving back and forth even though the lens wasnt moving. The camera goes thru the warm up, but never focuses, and shuts down after about 10-15 seconds of making this noise. I can then push the play button to view pictures stored, and the lens will retract. I cant take pictures either, and of couse the joke is that the last person I took a picture of broke the camera....Its funny, but not that funny, as my grandmother wouldnt be happy about that statement. Any advise would be helpful. Thanks.
  • COGAND123 Jan 04, 2008
    SAME PROBLEMS AS KIPPY 19 !!
  • howayy Jan 12, 2008
    Have the same problem. This is the second time ours has done this. Last time started working again, this time we don't seem to be so lucky. My Dad's Exilim did exactly the same and were told it needed a new motor that cost more than the original camera to repair.
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Jan 25, 2008
Anonymous
Contributor
Level 1:
Answers
34
Questions
0
Helped
15066
Points
41
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. Hint...google my user name.
Anonymous
Level 1:
Problem Solver:
  • Contributor 28 Answers
  • Posted on Feb 19, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
28
Questions
Helped
7774
Points
24
It sounds like you have broken off one of the teeth in the gearing system. I have used parts for your Casio at a reasonable price. [email protected]. Thanks
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Jun 28, 2007
SOURCE: Zoom shutter wont extend fully
the same thing happened to me. I took my camera apart - just removing the case. I then operated my camera and it became "unstuck". now it works just fine. I put the case back on and all is just as before.
Casio EXILIM camera lens will not extend fully!!!
Try plugging the PC interface cord into the external connector. No need to hook it up to your computer, just plug it in and out a few times. Then try to power up the camera.
Good luck.
Zductive
Says lens error!!!!!
A lens error requires to be sent into repairs. Give them a call at 800-706-2534 option 2.
Camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
Beeps 3 times
Is it an actual beep, or is it a beeping noise coming from the lens? Does the lens extend? I ask this because this is the noise the lens focus gears make when they are knocked out of alignment, or debris gets in them and jams them.
Casio EXILIM ZOOM EX-Z60... Problem
The power leads that are soldered from the main circuit board to the LCD are near the lens assembly ( about 7 o'clock). Did you break one of these? If so, it will need to be resoldered.
Casio EXILIM ZOOM EX-Z60 problem with not being able to get the LCD working after dis-connection and re-connecting the connectors
The LCD will not show the picture until you put the ribbon all the way inside the connector
Hope this helps
Joe
Casio EZ Z60
This is a major malfunction take a look here http://www.fixya.com/support/p472784-casio_exilim_zoom_ex_z60_digital_camera and contact the makers Tech Support
1helpful
2answers
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
