Question about Canon LaserBase MF3220 All-In-One Printer
Scanner does not scan anything. When i put it scan mode and try scan nothing happens.
  • 3,153 Answers
Ensure the software for the printer and the drivers are installed correctly first.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 11, 2009
  • 37 Answers
Change ur usb cable with original one
Posted on Oct 10, 2009
  • 117 Answers
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Posted on Oct 08, 2009
  • eng_amgoda Dec 05, 2011
    there is no scanner lock in mf3220 :)
Canon mp550 will not scan
use a different scan mode,like the one that came with computer
Apr 28, 2017 | Canon PIXMA Office Equipment & Supplies
We have recently purchased a Film/slide scanner model FS-500-S (base). I have been able to put our slides through the scanner without any problems and they appeared on our computer. However, now I am...
Hi Bev.I have just purchased the same unit. It scans,but the colors are terrible. Anything what you would expect.also the installation software does not indicate the type of scanner I have. But i have sold my problem. It is in the bin. I will not touch a Base product any more.
Nov 23, 2010 | Office Equipment & Supplies
HELP
If the weather band is working, the scanner should be working. To verify operation:
- Move the MODE switch to "Scanner" and power the unit ON.
- Press the SVC button (chrome button below display).
- Press POL (chrome button below display).
- Turn the SQUELCH knob towards the left until scanning stops and you hear a hissing noise.
- Turn the SQUELCH knob towards the right slowly until scanning resumes.
If the scanner stops on anything - even noise, it's working.
To Program:
- Slide the MODE key to "Scanner."
- Power the unit ON
- Turn the SQUELCH knob to the left until you hear a hissing noise, then turn it the right - slowly - until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 156.055).
- Press the E (PGM) key.
- Press the UP arrow (above the SCAN key). Scanner will move to channel 02.
- Enter your second frequency, including the decimal point.
You should now have two frequencies programmed. Press the SCAN key . . .
If it still will not accept programming, let me know.
BillB
Nov 07, 2009 | Uniden BC340CRS Base Scanner
My scanner comes on but does nothing it don't scan up or down but did at one point and time what is up with it?can someone help me
I've got a couple of options you might consider:
1. You may be in "manual" mode & the scanner's locked onto one frequency (one that obviously doesn't have much happening on it if you're not hearing anything!). Try pressing the "Scan" button, which will take it out of Manual mode.
2. You've accidentally "initialized" the scanner which means all of your frequencies have been deleted (sort of like wiping your hard drive clean). If that's what's happened, you'll need to re-enter all of your frequencies.
Oct 26, 2009 | Radio Shack Pro-97 Handheld Scanner
No response when printing or scanning
You have a bad scanner assy which will cost more to replace than a new printer.
Jul 02, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
Unable to get anything to scan?
Some machines require the purchase of an optional scan board in order to work. They still put buttons like "FAX" and "SCAN" on the machine even when they don't have that function on-board.
Just a thought.
Good Luck
Apr 04, 2009 | Office Equipment & Supplies
MP 160 Cannon Printer Won't Scan
try checking if you have completely installed all the drivers for your printer. scanning and copying dont usually needs drivers because you can do that even without a computer. but scanning requires your scanner to be read by your pc. try checking for the scanner driver from the cd that came from your printer.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HP F380 not scanning
This has happened to me on several occasions with a couple of different HP all-in-one scanner/printer's. The HP driver/program itself may be in a phase where it's attempting to complete a scan, which would prevent you from scanning anything else. You can confirm whether or not this is the problem by restarting your computer and attempting another scan. You'll get an error message saying the scanner is currently in use. You may want to try to completely remove the installation files for the scanner, and reinstall either from the disk or let windows install it for you via "plug and play". Then update the drivers from hp's website. See if that resolves your problem.
Oct 05, 2007 | HP DeskJet F380 All-In-One Printer
Canon LaserBase MF3220 All-In-One Printer Logo
282 people viewed this question
old marine
old marine
