If you remove battery door, the TINspire CAS cannot be turned ON.
You may try to reset the unit by pressing the reset button on the back of the unit. If that does not solve the problem, you may try to reinstall or update the OS.
Anyway, here is what the Texas Instruments Knowledge Base has to say about reinstalling the OS. Hope it helps.
What steps are required to reinstall the TI-Nspire family operating system?
To reload the device’s OS using a computer with TI-Nspire Computer Link:
• Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable.
• Open the TI-Nspire Computer Link software. The select device dialog should appear, and detect the device.
Either drag the OS file (available in the ‘downloads’ area at
education.ti.com) onto the TI-Nspire File Browser portion of the
window, or click Tools -> Install OS.
To reload the device’s OS using another TI-Nspire or TI-Nspire CAS device:
Connect the two devices using the USB Mini A to Mini B cable. The end
marked A should be inserted into the sending unit, while the end marked
B should be inserted into the receiving unit.
• On the sending unit,
access the document chooser by pressing [Home] [7]. Once in the
document chooser, press [Menu] and choose 9:Send OS…
NOTE: Users can only send an OS to a unit of the same model. Users cannot send an OS from a TI-Nspire to a TI-Nspire CAS.
Please see the TI-Nspire guidebooks for additional information.
