Question about Saeco VIA Venezia
VIA Venezia is already getting a bit old, but lately the coffee comes out only drip by drip. Cleaned it, tried different coffee types and grinds, no avail. Yesterday the pump slowly stopped making noise, this morning it made the noise again but a very slow drip. Any other suggestions besides buying a new one? Thanks in advance.
    President:
  • 1,618 Answers
Backflush the group and clean the shower screen.
Posted on Oct 08, 2009
  • iampivot Jul 17, 2013
    The via venezia doesn't have a three way solenoid valve, so you can't backflush it.
Is it worth it to get the machine fixed if the heating element no longer works?
Saeco Via Venezia - YouTube
? 3:10
www.youtube.com/watch?v=8L8vdfMOx2g
Nov 24, 2011 - Uploaded by TheSTiGUi
I dusted off my old Saeco Via Venezia, and wanted t. ... Quick run down of my incomplete modified Saeco Via Venezia Espresso Machine ... a start temperature of ~95deg C (obviously depends on boiler water temperature etc.) ...
Jul 28, 2015 | Saeco VIA Venezia
Making very bitter espresso. I already decalcified it and ran empty tanks through, without success.
Hi. The bitterness you have got is most likely to be dirty group head and shower. Remove the shower and clean with a steel wool. The group handle and filter basket will also have to be cleaned. Sounds like your using a dark oily blend. You cant use different blends unless you clean the group head every time. Same with the grinder. You can not use different blends for grinding. The different blends just cross contaminate, which can make your coffee bitter. Incorrect grind or wrong water tempreture can also make bitter coffee. Running descale does nothing for the coffee taste. Descale only cleans the lime/calcium in the boiler. Coffee does not pass through the boiler. Give your group head and handle a clean, and you should be right. Hope this helps. Dazza
Oct 21, 2011 | Saeco VIA Venezia
My Saeco via venezia isn't sucking up water for the espresso anymore, how to fix the problem? it isn't even a year old
The only thing that comes to mind is the pump, and an airlock in the hydralic system, try opening the hot water valve it water comes through then the shower screen on the group might be clogged.
Sep 09, 2009 | Saeco VIA Venezia
Water won't come through my Saeco via venezia coffee machine. It was working fine until I cleaned it so I don't think the pump has gone.
If the pump vibrates when trying to draw water then that is a good sign. Remo;ve the hose on the output side of the pump and turn it on to see if it draws water(BE Careful water and electricity love each other too much), it water flows out the output side, reconnect to boiler and test. If that did not solve the no draw problem then the machine is blocked either at the boiler.
May 11, 2009 | Saeco VIA Venezia
Knocked out spent coffe grounds come out mushy not like a puck
Adjust the grind on the machine, or the amount of coffee the grinder puts into the chamber.
Jan 12, 2009 | Saeco VIA Venezia
Coffee not pouring through portafilter
if your grounds are tamped down too tight, the steam can't get through it.
Dec 30, 2008 | Saeco VIA Venezia
Re: no coffee comes out after the grinding and loading stages!
Sounds like your coffee grinder is grinding too fine. I would up the size of your grinder. The larger the numbers the coarser the grinds. Also, should descale the machine if you haven't in a while. One of these two things may help.
Also, if the above two things do not work you can try to clean out your grinder using the instruction #2 posted on the website http://cerinicoffee.com/Saeco_technical_documents.asp
Sales, Service and Information of Saeco Machines visit:
www.CeriniCoffee.com
Hope Everything works out for you.
Oct 06, 2008 | Saeco Vienna SuperAutomatica Coffee...
Cannot express the coffee into the cups
Solution nr one cold be the machine ran out of water and the circuit need to be filled up again.
This is the procedure to do that
Fill up your water tank
Open the steam knob na push the coffe button...in that way the water will be forced to go to the steamer.If you have water in the steamer like you asking for hot water....go to the next step
Close the steam knob and at that point you will hear a different noise and the watewr should be able to go direct into the boiler and start dripping like it was before.
if you don`t have hot water coming oput from the steamer....the problem is before the boiler and could be a clog on the silicon tube or the water pump is loosing friction..
Pls don`t forget to rate your experience
Fabio
Apr 26, 2008 | Saeco VIA Venezia
Slow coffee drip
did you change coffee different coffee different setting lower our coffee setting move it only when it grinding only cheers
Dec 07, 2007 | Saeco Vienna Deluxe
Saeco VIA Venezia Logo
462 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
