Question about Canon PIXMA iP4300 InkJet Photo Printer
I tried to print a pdf file from the internet and now my printer won't work. It says it's 'off line' but even when i reset it to 'on line' it doesn't work. When i turn the computer on a Windows message appears saying it doesn't recognise the usb device.
  • 416 Answers
it sounds like you need to reinstall the software and drivers for your printer.....unfortunately canon uses java to help navigate their site so i cant post you a link, your going to have to navigate there yourself. Ill help you as much as i can.....follow these instructions EXACTLY!!!
  1. Click here to start at the canon home page
  2. click support on the left side of the page
  3. click canon usa
  4. once again select drivers and downloads on the left (yes you do have to do this twice, and yes it is dumb)
  5. select consumer products from the drop box (this will open a pop up window.....you may have to allow pop-ups from this site)
  6. Now in the "download library" you can proceed to enter your hardware info in the three selection and press go
  7. select your OS
  8. click on the link "ip4300vst200ea23us.exe" under drivers
  9. select to begin the download and install
WOOOO!!!!!!! hope you get all that with ease......i know it was a little frustrating for me to navigate all that but if you follow this little map i outlined you should be just fine!!!!!
GOOD LUCK AND PLS RATE THIS POST!!!!!!!!! :D
Posted on Oct 08, 2009
    Guru:
  • 830 Answers
Uninstall all the software for the printer. Reboot computer and reinstall the printer software. Do not plug printer in until the software tells you to. This will solve the issue.
Canon MX860 won't scan to a pdf
Scan and create PDF documentYou need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
From your computer SCAN your document then click on File - Print and select thePDF writer as the printer device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :-http://www.cutepdf.com/
May 18, 2012 | Canon Office Equipment & Supplies
"Communication Not Available" message is displayed
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
My printer will not communicate to my printer, and it did recntly. just stopped working a month ago.
Do a normal power off (leave the printer powered on) on the computer and after 5 seconds re-power the computer on and you should hear the printer do a reset and become ready. I've had the same problem, it's in the printer.
Jul 22, 2011 | Lexmark X5650 All-in-One InkJet Printer
Printer does not print. have prints in que but doesnt print
Have you tried a quick reboot? Of course, save the file you want to print, reboot your PC and try printing it again. If this doesn't work, try removing your printer in the "Devices and Printers" that you can find in the control panel (or Printers in XP). After removing, try adding a new printer again. Don't worry, you won't need drivers then because the driver is already in your PC after you installed the printer the very first time.
I hope this helps... (,'')
Jun 04, 2011 | Office Equipment & Supplies
Printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Jun 05, 2009 | Lexmark X6570 InkJet Printer
WHEN TRYING TO PRINT TO THE DOT MATRIX PRINTER NOTHING HAPPENS
it looks like it was hanging, reset the unit again and cancel all spooled file that you wish to print, even all the queued file, the file was somehow corrupted along its way
Nov 27, 2008 | Panasonic KX-P1131 Matrix Printer
Adode Acrobat Standard PDF Files won't print on A3000
I've had the same problem when using Acrobat 7.0. I reinstalled version 6.0 and it works fine. You may even want to try a different reader such as Foxit.
Jan 04, 2008 | Compaq A3000 All-In-One InkJet Printer
Will not print pdf files
first you check with the printer test page if it proper then may be problem with the pdf file. try to remove from some other pdf file and see.
Jan 26, 2007 | HP PSC 2210xi All-In-One InkJet Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
43 people viewed this question
old marine
old marine
