Question about Music
Laney GH50L guitar amp head and cab. The bypass switch works fine but suddenly the insert/side chain positions for the FX loop has stopped working resulting in the volume dropping so low and sounding so tinny with no effect being added either. Is there anything I can do myself to fix this or am I looking at a daft repair bill?
  • Music Master
  • 5,603 Answers
The symptoms are common to a capacitively coupled signal which is often a bad switch on an insert jack that is bent so as to not contact the signal to pass it to the power amp.
The jacks on MANY of these amps are plain JUNK. If a cable is yanked a bit it can bend the spring contact. When the conttact is very close, but not touching, the capacitance will pass the high frequencies but not the low and ALL frequencies will be very attenuated.
Posted on Oct 10, 2009
Why do my laney 100 reverb combo lights come on but no sound?
First, plug your guitar and cable into a different amp to make sure the problem is the amp. Then check to see if you have output from any headphone jack or effects loop. If so your problem is in the power amp section. If not, it's likely the preamp section. Whichever section it is, it will most likely need to go to the shop.
May 21, 2016 | Laney Music
Behringer ac 112 guitar amp powers up, display works. dials act normally, but no sound. only static as volume turned down (speaker works). amp was left on for long period
Try putting guitar trough the FX Loop, if there is still no sound, you may have a problem with the Power Supply.
Oct 01, 2013 | Music
I have a marshall jcm 900 slx 100 watt head and 1960a cab, when i went to use my amp i got no signal from my guitar. none of the fuses had blown and there was still a hum coming through the speakers. I...
It sounds like you have a dead guitar cable or the preamp section of the amp is blown. It needs to go to the shop. It's way cheaper in the long run to just take an amp in. If you try poking around without knowing what you're doing you can fry something more expensive or worse yet yourself! There are leathal voltages in a guitar amp!
Aug 17, 2017 | Music
Marshall mg100hdfx head. I get no sound whatsoever plugged into the guitar input but the controls seem to work as I can hear changes in the light ambient static. I will get sound however if I plug directly...
You MAY have a broken input jack. If you can hear changes from the overdrive gain control, that control is just one stage away from the input jack. Also there is a capacitor C60 that is for RF bypassing and if that shorts that will kill the audio. Yes, inout jacks get destroyed by tripping over guitar cables... that is why you run the cord through the amp handle before plugging it in. Of course verify your guitar and cable is good using another amp.
Aug 30, 2011 | Music
My DL4 doesn't sound as it should in my series fx loop. Is there any way possible to solve this problem WITH OUT putting it directly into the amps input? I need help!!! I play my amp wich is class A...
your parallel loop only has input, a series has out and in, you need to patch the out of amp to the in of the pedal, and out of the pedal to the in of the amp fx loop. then you need to make sure your loop is turned on, via switch or footpedal.
Jul 05, 2011 | Line 6 DL4 Delay Modeler Effects Guitar
I get a hum whether the guitars plugged in or not...same problem with my GH100...happens at different locations...so that rules out outlet wiring...
A low hum may be perfectely normal in these, however if you can hear it four feet from the speaker that would be too loud.
Filter capacitors are always suspect, but an oscilloscope is the correct tool to diagnose the problem.
Mar 06, 2011 | Laney GH50L 50 Watt All Tube Guitar Head
It lights up but there's no sound what so ever... /Nicke
Hi, when ever an amplifier comes on and no sound with it,it means that you will need to replace the sound IC that controls the sound that comes out from the output.
When you replace it the amplifier will be fine.
Have a nice day.
Feb 22, 2011 | Laney GH50L 50 Watt All Tube Guitar Head
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Music Logo
161 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
