Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Toshiba 46In HD Rear projection TV Vertical lines on screen
Over the last several weeks, my 4 year old Toshiba rear projection TV has vertical lines on the screen when I turn in on, sometimes they disappear within 5-10 minutes, other times it may take hours, if at all. I've had cable tv people check the HD box which they advise is working ok, but I still had the vertical lines on the screen with the HD box off, . and switched to regular TV I still have basic cable coming but the vertical lines were still there. I'm confused because when the lines clear up the picture is great, but the vertical lines can start up at any time. Do you think it may be a TV problem or the Cable line coming into the TV is bad? Again, when the HD box is off, the problem still exists but does eventually clear up. I have 3 other TV's in the house, no problems on those at all at this time.
  • 3 more comments
  • screaminsal Jan 05, 2008
    i have the same problem. it started out with a vertical line on the right side and now it has progressively gottwen worse. line and the t.v. is completrely blurry. it use to take 15 min to clear but nowis blurry all the time.
    how much to fix?
    can it be fixed ?
    whats the problem?
  • deborahb1969 Jul 07, 2008
    I just started to have the same problem. I bought mine in January of 2004. I initially thought it was my DVR that was causing the problem, but when I hooked up the box to another tv in my home, the picture was great. The picture is the worst when I first turn the tv on, and then it will sometimes get better the longer it's been on. The picture is also bad when I watch a DVD, another reason I think it's the tv and not the DVR/cable that is causing the problem. I described the problem to a tv repair technician (the same one that had to fix this same TV 2 years ago for another problem--thankfully it was still under our extended warranty) and he told me the repair would probably cost around $450-$500.00. I'm not sure it's worth paying that.
  • EagleFan47 Sep 16, 2008
    We have a 52" rear-projection Panasonic, and there are vertical blue lines going down the tv every 11 pixels, totaling 101 blue lines !! the lines are there all the time, watching any channel, movies, and games. Is there anything that can be done to get rid of these lines ?
  • megadethmutt Nov 09, 2008
    I have a similar problem with 46H84 toshiba, the lines fade within a couple of minutes. However, while watching Tv it will switch to a blue screen then completely turn off. The On/Off light will start flashing. At this time the only way to get it to work again is to unplug it and plug it back in. Sometimes it works sumtimes it doesn't. Real Frustrating at times. I have a great picture (when it works) and have only had the tv about 4 years. Im beginning to believe I wasted a lot of money when I purchased it. Toshiba has had a leading name in electronics, but now, I'm beginning to wonder.
  • Anonymous Feb 24, 2009
    I have had the same problem with the 46H84 toshiba - while no expert, my sense is periods where we had the picture settings much higher have worn out components. The lines used to go away after an hour or so, but now can take days of leaving the TV on (in sleep mode) to make them not that noticeable (and they're still there).
    I think this is different than other problems noted above - blue lines with the panasonic, etc - and knowing how much tv repairs cost, I'm unfortunately going to just replace this. Was a great TV for 4 years, but now its unwatchable for the first 10-20 minutes that its on.
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Posted on Apr 30, 2008
Toshiba Rear Projection TV Picture Problems
The convergence circuits need to be replaced Sometimes it is just the matter of 4 capacitors and an IC but often than not ythe whole board has to be replaced.
Sep 02, 2009 | Toshiba 57HX81 57" Rear Projection...
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Vertical green lines
Call where you bought the TV. This is not normal for an LCD TV. They should exchange it only being a week old.
Jan 20, 2008 | Televison & Video
Aging 43H7143
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Vertical Stripes on My Mitsubishi WS-65809 Projection TV
Nov 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Nov 18, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 46in Rear Projection TV Model#46H83
sammy jo ,you burnt the tubes by leaving it on with a vertical collaspe faultmnow you have three damaged tubes,i also think that you also have a bad yoke which is taking out the new parts ,the cost is within reason,the shop repair is to insprct it deeped for possible other faults and damage already done.
Oct 14, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
2,945 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
