Question about D-Link AirPremier DWL-2700AP 802.11g/b Wireless Access Point
Sometimes i try to ping the wireless access point and i get the message 'Request time out',i receive this message even if im directly connected to the access point.what should i do
  • 2,263 Answers
When you connect the computer directly to the access point, you might not be getting IP address on your computer.
You will need to assign a static IP address on your computer in the range of default IP address of the Access point.
Click Here for More info on access point
Posted on Oct 08, 2009
  • Prashant M
    Prashant M Dec 05, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
Problem in my device TL-WA5210G or from network help me
please forward your access points configuration. how do you configured it ? which isp your using ?? and from which country ?
Apr 16, 2013 | NEW Asi Tp-Link Nt Tl-Wa5210G Outdoor...
D-Link problems
open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway, it should be your IP address.
If you are still unable to browse the Internet, ping your router's connection to the PC. Open Command Prompt, type 'ping 192.168.0.1', hit Enter. If your PC is receiving connection from your router device, you will see a message like Reply from 192.168.0.1: bytes etc. If there is no connection, you may see the Request timed out message.
The Request timed out error can occur due to two things: (1). incorrect physical connection between your router device and the PC or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
If you need any kind of technical assistance you can contact support cell at here
Jan 23, 2013 | D-Link DIR-628 Wireless Router
Staus led not blinking after a fw update
You are going to have to find a software that helps you force reinstall the Firmware. Something went wrong somewhere, I know the software exists, i used it to install a 3rd Party Firmware on my linksys to gain Access Point Functionality
Apr 14, 2010 | D-Link AirPlus DI-524 Wireless Router
We ave lost our connection on our one computer to
Its sounds like it could be a number of problems. One problem may be that your computer's IP Address may have become invalid (expired, or other reasons). One way to fix this is to go to command prompt on your computer, and use the commands "ipconfig /release", and then "ipconfig /renew". After that, use the ping command to test connectivity. To do this, type in ping, and then your router's address (i.e. ping 192.168.1.1). If you get replies from your router's IP, then your connection is working. If you get a reply from an IP starting with 169, then your networks settings are probably incorrect. If your request times out 4 times, then you have other issues. In the case that your requests time out 4 times, try "ping 127.0.0.1". If this ping does not work, then you need to replace your NIC card.
If you still need help after performing these steps, or if you just have questions about the information in this solution, please feel free to contact me.
Feb 24, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Why cant i access sites on my laptop it comes up with security certificate also i cant acess my email account on google its all new to me never used a laptop before and im not sure if it comes with any...
If you cannot access any website on your laptop check if you have interent connection first. Check if your laptop is set to connect using a proxy server check the Local area connection. If your using wireless check if you wireless setting is correct. Run ping test to determine your internet connection For windows click START > RUN > type ping yahoo.com if the message is reply from then your connected check you laptop security settings. If unable to connect or request timed out contact your internet provider
Nov 20, 2009 | Google Gmail
Connection to linksys wrt300-n router drops frequently from wirelessly connected laptops - even when sitting in the same room mere feet away from the router. I've set it up to use MAC filtering and AES...
Try to Disconnect and Connect the Internet Manually in the Wireless Network Connection. Also this can be a problem with our Computer or Laptops Lan Card which may be having issues in connecting.
Sep 13, 2009 | Linksys WRT300N Wireless Router
Default gateway
When you ping the gateway with your computer it could not communicate with the gateway.
Assuming you are connecting via a network cable.
Either the network cable is broken or network card is faulty or it is configured incorrectly.
Make sure your TCP/IP address of your network card has the same TCP/IP address range as your gateway.
Jul 24, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
D-Link DWL-G700AP Access Point
You need to connect the access apoint directly to a pc with a CAT5 cable then set up a static ip on the pc which I assume you know how to do it, for the static ip put 192.168.0.5 subnet is 255.255.255.0 and gateway is 192.168.0.1 then save the settings, then check first if there's a good connection between the access point and pc, go to the command prompt then type PING 192.168.0.50 if you receive 4 replies go now open the http://192.168.0.50 if you receive 4 request time out reset the access point and and ping it again if still 4 request time out after you reset it replace that access point.
Jun 06, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
WEP KEY
disabling WEP security is not a great idea, unless you plan on replacing it with WPA. As for your request, please open a Browser and enter 182.168.1.1 into your address bar and hit enter. I can't seem to recall exactly where the setting is, but you will come across it if you look through the router admin page. Hope this helps.
Dec 21, 2007 | Computers & Internet
ActionTech Wireless Gateway can't route Wireless to LAN
Disable firewall on all devices. All types of security sofwares should also be disabled in order to ping each devices.
Oct 07, 2007 | Actiontec GT704WG Wireless Router...
D-Link AirPremier DWL-2700AP 802.11g/b Wireless Access Point Logo
379 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
