Question about Samsung SyncMaster 2233SW Monitor
My friend just plugged in her monitor and all settings are wacked. The screen image is stretched...how does she change the resolution and color on her 2233sw monitor...
    Guru:
  • 830 Answers
Close all windows. Right click on desktop. Choose properties and resolution. Change settings to prefered view.
Posted on Oct 08, 2009
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Wide screen stretches all my photos
Dec 09, 2011 | Samsung Computers & Internet
The images on the monitor are stretched lateraly
Depending upon the screen resolution that has been set in Display, the image will be distorted on these wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle. When you are satisfied then click apply.
Feb 24, 2011 | LG W2053TQPF 20 inch Monitor
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
I use Microsoft XP and I use a 24" Samsung widescreen monitor. Is there any way I can get my programs to fill the screen without stretching and distorting. I have a friend who has a Dell widescreen...
Its probably your screen resolution, you probably want it set to something with a 16:9 or 16:10 ratio so 1280x768 or 1280x960 or if you are like me and like lots of real estate 1920x1200
Sep 09, 2009 | Computers & Internet
Images Stretched
go into control panel/display and check your resolution. It sounds like the resolution may need to be changed. You can try 640X480 or 600X800 and see if that makes a difference for you.
Aug 11, 2009 | Acer X191WSD Monitor
Monitor stretches the images. How is it possible?
you might just need to touch the resolution or else check if the monitor has right settings from its inbuilt menu.
Mar 17, 2009 | iiyama ProLite E481S-B 19" LCD Monitor
Acer P193W monitor stretched image
What service pack of windows xp are you running? Also, do you have your old monitor, if so, then plug it in and see if the same problem occurs. If not , go under the settings for your graphics card (not windows display options) and see if there can be a correction made to the settings for your monitor. Also, try going to microsoft.com and updating your computer (it's free) and you'll probably get the required driver to fix the problem from them. Check under your control panel and see if you have automatic updates turned on, if so you may want to limit what updates are to be installed by allowing updates but you choose which one's to install. Hope I could help. My e-mail
tallcoolone@yahoo.com .
Jan 04, 2009 | Acer X193W LCD Monitor
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Samsung SyncMaster 2233SW Monitor Logo
184 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
