Sound card issues
How do i fix my sound card. computer says i have no audio output
  • 33 Answers
Probably a driver issue. Simply get the CD that came with the card or download the drivers off the manufacturers site and then reinstall the drivers, restart your computer and hopefully it works again
Posted on Oct 08, 2009
Finlux tv
You have to check its speakers first. If found OK, check and replace damaged component/s at its audio output circuit. If needy, replace the audio output card.
Jun 30, 2013 | Televison & Video
Headphone jack does not work
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Jan 21, 2013 | Acer Aspire Computers & Internet
Is my sound card damaged? My sound driver is present and i think it's working fine, sound bars are moving also when i drag the slide up and down. But, theres no sound coming from built-in speaker...
Based on the information you have provided, it seems that the issue might be with the Audio Output Jack.
Usually some Computers have an additional Audio Jack on the CPU.
If you have such an option you can try connecting the Speakers and Headphone to that Audio Port and check.
If you do not have an additional Audio port, then it is confirmed that the issue is with Audio Output Port.
It is recommended to replace the Sound Card. You can also check with your favorite Computer Retailer, if only the Audio Output Port can be replaced.
Please let me know if you have further questions or need any assistance.
Suresh....
Jul 29, 2011 | Acer Aspire 5535-5050 Notebook
My Toshiba Satellite A135-S2386 laptop all of a sudden says "no audio output device is installed" any help on how to fix this would be appreciated! I have gone to device manager, however states there is...
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 13, 2010 | Toshiba (4CH-VOUT) Sound Card
Sound card no found, no audio output deivice is install and sound, game cotroller not found, pls help
No Sound, No Volume Control, Mixer not Found, No Sound device installed…etc etc, This is a generic issue with all Windows OS updates....many of the users are facing this issue....this issue began after an auto update from MS changed many IRQs of Win OS, mainly the Sound and Audio Control system of Windows.
1 - R U facing NO Audio / No Sound issue...?
2 - Is ur Volume Control not responding ?
3 - Is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
If ur ans to any one of them is Yes...then u are being spammed by Microsoft....as ur Sound Control IRQ is being frozen by a recent update from Microsoft....
NOTE..THIS…IS…VERY..IMPORTANT...
No file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it…or giving any help on this.
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service and help everyone affected by this stupidity from Microsoft.
www.sureshayyar.110mb.com
visit my support page.
all the best...
Jan 08, 2010 | Acer (54.AA806.001) Sound Card
I have no sound at all..everything tells me that all is good and enabled, could it be my card is caput....
Can you please tell me if when you turn on the computer if you are getting sound windows sound. then it is some settings in the computer check if mute is not checked or check in device manager if the correct sound drivers are installed.
Jan 03, 2010 | Creative Labs SB0100 Sound Card
Problems with audio after installing radeon hd 2400
This happens because the video card has hdmi output. Since hdmi output can carry audio signals also, the audio driver gets disabled. Uninstall audio driver and video driver both, install the video driver, and then install audio driver. after installing the audio driver, in playback and recording devices choose choose the audio output device you purchased along with the computer. This should fix the issue.
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 12, 2009 | Diamond Multimedia Stealth RADEON 9250,...
NO SOUND
have you check your audio driver? audio driver drives audio output its nothing to do with video card. reinstall your audio driver to fix it.
Jul 13, 2008 | Computers & Internet
No sound from output 3/4
hi
u can try this , please update the driver update for the same issue and update the driver for the sound device or please unistall and reinstalle the sound drivers on the system, or do systemrestore if it was working some days back .... check the
  1. Click Start , Run , and enter services.msc into the Open field. A services window opens.
  2. Scroll down the list of services and find Windows Audio.
  3. Right-click Windows Audio and select Properties .
  4. Select Automatic from the Startup type dropdown list, and click Start to start the audio service.
  5. Click OK and test for sound.
May 24, 2008 | M-Audio Delta 1010 PCI CARD Sound Editing...
Won't work
Um, that sounds like a sound card drivers problem more than the speakers theirselves. Can you try connecting any other source of audio to the speakers, like a Mp3 player, a walkman, a diskman ? Those portable players have the same audio output connections than a PC's standard sound card, a 1/8 mini stereo plug. If it works fine this way, it's a sound card drivers issue. Now if it's so, what i'd suggest you to do, is to check which sound card you got, and to reinstall or update the drivers for the device. I can help you with that part too, keep me posted on the status. Thanks, cheebster :)
Jun 23, 2007 | Logitech R-10 Computer Speakers
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
