Question about HP Compaq 8510p Notebook
Compaq 8150p bios password need to be reset. Is the cmos battery soldered on or unplugable.
  • chris74898 Oct 08, 2009
    its the compaq business 8150p if that makes a difference.
    Scholar:
  • 74 Answers
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Oct 30, 2009
  • HP Master
  • 32,281 Answers
The BIOS battery could be a button type battery or it could be a battery with a plug-in lead.
Posted on Oct 08, 2009
Reset bios password
there is linux utilitysoftware out there that you can boot and find or reset the bios password
or you can disconnect the bios battery for 15 seconds to reset the bios to default.
some laptops have a removeable battery you can unplug but most cmos batteries have leads that are soldered onto the motherboard.
you would have to use a soldering iron to melt the solder on the positive lead and lift it away from the board.
after 15 seconds you can resolder it back in place.
Aug 20, 2013 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
Compaq 6510b reset cmos/bios password
try this: Make sure the battery for the notebook is out in step 8
the procedure to reset the CMOS/BIOS is in the maintenance and service guide on page 46.
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the
computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery (see Battery on page 48).
5. Remove the real-time clock (RTC) battery (see RTC battery on page 68).
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Jul 27, 2012 | HP Compaq 6530b Notebook
Bios password reset
to reset the bios password you will need to remove the cmos battery from your computer. open your computer and locate the cmos battery. it looks like the size of a nickel. make sure your computer is powered off and unplugged.
Feb 15, 2012 | HP Compaq Presario SR5210NX Desktop PC...
Hello, can help me, my laptop ACER EXTENZA 4630 SERIES, why i can open the password bios when i re install the laptop..? thanks
Yes by default the bios is unprotected/no password. All you have to do if you want to setup bios password just go to bios then create supervisor password then it will have password everytime you need to access the bios. For info. bios password is not related to re-installation / installing your OS.
Mar 12, 2011 | Computers & Internet
I need a pasword.when i enter the bois there need a pasword.so help me how 2 break the pasword
Hi Good day!! turn off your PC Remove your CMOS battery (2032 3volts) within 1minute and then put it back, turn on your PC now your bios password should be remove.
Oct 19, 2010 | MSI Microstar KT6 Delta (MS-6590)...
How can i remov the hp compaq nx6310 laptop bois password
If you didn't set it or do not know it then the entire laptop will have to be dismantled to remove the cmos battery for one hour to cancel that password.There is no easier way.
Oct 16, 2010 | HP Compaq nx6310 Notebook
Give me password for compaq evo n600c
You can remove your bios password by reseting your CMOS battery or jamper. You need to open your notebook remove first the battery and all screw at the back of your notebook. You can see there a CMOS battery together with the CMOS jamper. Just read it you can read CLRSCR which means clear cmos, just pull it with in 10 seconds and insert it back. Now you are done to reset bios.
Mar 03, 2010 | HP Compaq Evo Notebook N600c
How to remove cmos/bios password ?
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
How can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
how can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
May 04, 2009 | HP OmniBook 500 Notebook
How do i remove bios password
There are many known ways to reset / remove / bypass the password:
* By removing the CMOS battery
* By using the motherboard jumper
* By using MS DOS command
* By using software
* By using Backdoor BIOS password
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
Mar 13, 2009 | HP Compaq Presario 2500LA Notebook
HP Compaq 8510p Notebook Logo
1,576 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
