Question about Hotpoint Aquarius WMA42 Front Load Washer
The Door won't release and I have all my washing in! It's saying it has finished the wash. It's an Aquarius silent. Is there a way I can manually release the door?
    President:
  • 1,304 Answers
You should be able to pop of the toe kick
behind that is a gree or red or tasn platic pull
thats the manual door release
Posted on Oct 08, 2009
Testimonial: "Aces, if this works you are a saint"
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
My wash/dry cycle has finished but I can't open the door. Is there a manual release please?
turn the dial and listen for a click to release the door. no their is no manual release
Jan 06, 2015 | Electrolux Washing Machines
Door lockedshut with washing inside
Disconnect from the power socket. Leave for 5 minutes.
If still not opening, ensure it is not plugged in and remove the lid by unscrewing fixings at the back and sliding forward.
Catch can then be released from inside casing by sliding lock bar.
Will need new door interlock assembly.
Jul 05, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
DOOR IS STUCK ON LOCK
there should be a release handle some where, either behind door at bottom where you clean pump out, or if you take soap draw out.also check machine has finished cycle
Jan 22, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Door locked
You cld try 3 things:
1 Find the button on your panel which has the 'key' symbol, press and hold this down till the lock light goes off.
2 Hold down 'options' & 'select' buttons together till the light goes off.
3 Press 'end of cycle' button for 3 seconds, lock should come off.
Pl post back results. Rate if helped.
Mar 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
202 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
