Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
When i power on my monitor screen not appear no beep count
  • Albertus Kriel
    Albertus Kriel May 11, 2010
    what you meen with beep?
  • Albertus Kriel
    expalin exactly what you treid already
  • 22 Answers
OPen the case of the system unit. Check the memory, attach it and reinstall it to the memory slot. Check also other peripherals connection maybe there is a lose contact connection.
Hope it will works,
geloaa
Posted on Oct 09, 2009
I have compaq 610 laptop which is having windows 7(original) and purchased on december'2009 from M.S.Subham Computer Siliguri.It is not booting and giving some bip sound. I have doubt that the ram may not...
610, the post above contradicts, laptop and disktop WHY?
no service tag presented. by you... (p/n of LT)
no need to post a store, we are in USA< not there. so
why not get the PC repaired in a real PC repair shop.
asking how to fix a pc with no full symptoms is hard
we are not HP here, we are fixya chat boxes,
so why ask here, and not real HP?
on the below page, see bottom left of page
see "contact HP" bingo?
https://h30434.www3.hp.com/
so if you what free help only say so.
if you cant ask HP say so.
all we know sofar is beeps.
and no boot.
this is all wrong, order.
at least its a desktop. nice. oops it's NOT a DT.
but has monitor too, unstated monitor.. that can fail.
so.... oops id dont ....
answering for. this, i guess its this, is it?
made in 2009 , not too old, at all.
https://support.hp.com/us-en/product/Compaq-610-Notebook-PC/3958407
the PC beeps what is the beep code.
does the screen ever show any text ever.
try the external VGA jack on LT to an external monitor.
does the monitors menu button show OSD screens?
I know that most post here show checking ram first
its a wild silly guess that.
the fact is it can be many things wrong.
so step one
1: what beep code is it, count them , it repeats so count them.
2: is there text or anything ever on the monitor, ??????????
3: does BIOS screens work, power on hammer F10 key?
2009 PC can have the solder ball proplems.
same with CCFL tubes dead.
Hdd failure
and for sure the small coin cell battery dead. this old.
see the black screens of ***** here, NO TEXT EVER on screen.!
http://pcdied.com/black-screen.html
question one, what doesy our sevice tag show, on page 48 here.
lacking these facts, I cant help; much , no can REAL HP
they demand it , in fact.
line 1 ,3, and 4 are critical facts,
http://h10032.www1.hp.com/ctg/Manual/c01787889
Oct 15, 2017 | HP Compaq 610 T5870 156 WH248UTABA...
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
I press power botton but it keeps blinking
disconnect signal cable and give power to monitor and see "no signal check the signal cable" massage appears on screen if so then monitor is ok fault lies in cpu open the cpu disconnest the ram and listen whether contineus beep comes or not if comes then ram is faulty if not then motherboard is faulty
Mar 12, 2010 | Computers & Internet
Black screen after factory BIOS reset
Have u connected signal cable to the monitor? Is it ON?Try with different monitor
May 07, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Blank screen on AL 2223W
When you switch on the computer and monitor does the monitor power light illuminated?
If not check the power cable, if the power light is on try connecting it to another computer, if it works on another computer then the fault is in your computer or a faulty video cable (try another video cable).
If the monitor does not work then it is faulty, if it is OK then your computy is faulty.
If the fault is in your computer, you didn't exactly pinpoint the nature of your fault.
Does the power light on your computer illuminated when you power up?
Does your computer actually boot up, does it give and beep code (count the number of beeps - 7 beeps usually means video problems, depends upon the type of BIOS)?
When your computer first boots up and you see POST information on the screen then nothing, it is most likely :-
1. The refresh rate of the video card has been set too high beyond the monitor's specification.
2. Video card configured with incompatible monitor.
If you computer fires up and the monitor is OK the you have a faulty graphics card, you need to replace it.
Nov 12, 2008 | Acer Monitor
Power on problems
the beeps mean that there is some hardware problem
if u count the number of beeps or is it continuous???????
ne way
try taking out the RAM and again placing it
the RAM might be loose
Oct 27, 2008 | HP Media Center m7260n (EG642AA) PC...
Solid amber power light
Your Monitor is not connected properly
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Connecting Your Monitor
1. Turn off your computer and unplug the power cord.
2. Connect the white connector end of the DVI cable attached on the monitor to the connectors on the computer.
3. Connect the USB cable that was included with your monitor to the computer and the upstream USB connector on the monitor. Once this cable is connected to the computer and the monitor, you can use the USB downstream on the monitor.
4. Connect any USB devices.
5. Connect the power cord.
6. Turn on your monitor and computer. If you do not see an image, see Troubleshooting Your Monitor.
NOTE: The Monitor will display full screen in White, Black, Red, Green and Blue color rolling pattern on screen if the DVI cable is not connected. This self test pattern will be displayed continually when Monitor detects that DVI cable from Monitor to PC is not connected.
* Check connection integrity at both ends of the video cable.
* Ensure the monitor and computer are plugged in to a working electrical outlet.
* Ensure power button is depressed fully.
Aug 14, 2008 | Computers & Internet
Warning beep no boot
Re-seat the video card and memory first,
if it continues to beep count the beeps 3 long ,3 short .etc
they mean a code.
if you have 2 sticks of memory try using one.
Feb 14, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Garmin street pilot III
Push the power button to turn it on then count to 5 then hit enter. Then count to 5 again then hit enter. Once there hit the power button with a real quick press. The power button is also the screen brightness button. Someone may have turned it all the way down. OR the back light could have gone out.
Aug 16, 2007 | Garmin StreetPilot 2610 GPS Receiver
Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
88 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
