Question about Kitchen Ranges
Oven wont stay lit
Hi
I have just got a garland cooker at auction ,a note on it said the pilot light had been disconnected to save gas,the oven will not light, if I heat the sensor near the pilot the oven lights then goes out ,any way of bypassing the sensor ?
lez
  • 74 Answers
Thermocoupler is bad or your not holding the pilot on long enough the get the thermocoupler hot enough
Posted on Oct 08, 2009
I have a Garland Sunfire 36 inch gas Range. oven does not come on again after reaching temp.
You probably have a bad thermocouple. Try cleaning it off with sand paper. It's the part that the pilot light is igniting.
Mar 15, 2012 | Garland SunFire SX-10-26 (Gas) Stainless...
Oven not working. gas on stove top is working. not sure if gas is not getting to oven or if there is another problem causing the oven not to heat up.
Check the pilot light assembly.Make sure the pilot is lit.If it looks good the thermocouple may be bad. If the pilot is lit,I would call for the repairman.
May 17, 2011 | Garland G60-6R24RR Gas Range
Don't know how to light the pilot light in the oven.It is a Garland ten burner two ovens. It is about 11 years old. Where is the pilot light and how do I light it.
Most commercial ovens have a manually lit pilot. There will be a button somewhere on the range that you will need to push in so gas will come out of the pilot assembly. While holding this button you will the light the pilot and will need to hold the button in for about a minute or two until the pilot stays on after you release the button. Look around the bottom panel,top panel or side panels(you may need to remove one) to find the button. they are usually red and may not look like a button. If you find the button and the pilot does not stay lit then the thermocouple might be bad. If you push the button and do not get any gas coming out of the pilot then there might be debris in the pilot assembly causing the gas not to come out. In that case you could try and tap the assembly or blow with compressed air to clear it. But in most cases you will need to remove the pilot assembly and use a really fine wire(like a metal tie-strap minus the coating) to clear the pilot orfice.
Sep 30, 2009 | Garland Ovens
I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Aug 27, 2009 | Garland H286 Gas Kitchen Range
Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Mar 04, 2009 | Garland H283 Gas Kitchen Range
Garland gas oven pilot light won't stay lit. We have cleaned it and depressed red button for varying times up to 10 minutes. Adjusted flam
The ovens are protected by a thermocouple. It's the steel rod that the pilot flame heats up. The idea is simple- if the thermocouple doesn't sense heat from a pilot flame, it won't allow the gas regulator to send gas to the oven burner bar; it won't even allow the pilot to stay lit. Easy to replace. My Garland oven uses a 24" thermocouple. Any good hardware store has them for around $10. Just take off the skirt that covers the over-ride buttons on the regulator. You'll see the other end of the thermocouple there. I recommend taking the old one with you so you know which length to get. When you install the new one, just curl any excess in a nice big loop & tuck it out of the way.
Feb 15, 2009 | Garland Kitchen Ranges
Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
Dec 22, 2008 | Garland H283 Gas Kitchen Range
Garland Range
You may need to hold the red button for a couple minutes...
Apr 23, 2008 | Garland H284-24G Kitchen Range
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
Oven pilot light won't light
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Mar 05, 2007 | Garland H286 Gas Kitchen Range
Kitchen Ranges Logo
260 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
