Question about Motorola Mobility SLVR L7 Cellular Phone
Motorla Slvr L7 Won't hold charge
Battery charges full in 1 1/2 hour then holds for 1 day or less. Changed the battery, phone & charge at different times still the same problem. Is this normal for this model?
  • arundeepa Dec 26, 2007
    To
    The manager(complaint)
    Motorola India Pvt Ltd.
    Sir/Madam
    This is to lodge complaint about malfunctioning of our mobile (Motorola L7 IMEI 359195-00-202605-7.)
    The set was purchased from C.D. Gallery,Rathyatra,Varanasi, on 03.01.2007.Initialy it was working properly but since september it started giving problem in display.The complaint was lodged in Gaziabad authorised service centre UCom Technologies Pvt Ltd(work order no. 104 and 811 dated 14.09.2007 and 22.08.2007 respectively) . The set was repaired the display problem was resolved but battery started getting discharged within 2-3 hrs.Hence the mobile was given to the same centre twice for battery problem.It was handed over to me without solving the problem .The set was brought back to Varanasiand was given to the shop from where it was purchased .The mobile was returned without any fruitful result.Hence I am forced to contact you for getting my mobile changed or repaired as early as possible as my warranty expires on 02.01.2008. Is it my mistake I had purchased motorola handset?
    Yours Sincerely
    Dr A.S.Pandey
    26.12.2007
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 52 Answers
Just bought a new battery for mine off of ebay, and I still only get 2 days standby time on it! pretty crazy..
Posted on Mar 19, 2008
    Problem Solver:
  • 7 Answers
It depends on how much talking your doing. The Slvr is known for its low talk-time battery power. My slvr would last about 3 to 4 days on a charge, unless i was talking on it a lot. sometimes i would be charging it every other day. So it really all depends on the talk-time. Invest in a car charger for sure.
Posted on Dec 24, 2007
Sony ericson t290i no power
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 09, 2012 | Motorola Mobility SLVR L7 Cellular Phone
My Motorola SLVR L7 Cellular phone displays invalid battery even as i have changed the battery. It does not charge also, please help me.
hi
there must be error functioning in hardware of your mobile.. contact your service men of your mobile. this will fix your problem..
thank you
Dec 22, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Apr 28, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Charging problem
there is nothing wrong with your charger. The problem is from your battery.
The battery cell is very weak, such that it does not have the ability to with hold power for long.
Therefore, get another battery and the problem will be resolved. But make sure you charge the new battery till its full before you start using it.
Take care.
Mar 10, 2010 | Nokia N70 Cellular Phone
Nokia n73
The battery is faulty or needs replacing. All rechargable batteries lose their efficiency over time meaning that they hold charge for less time. It sounds like your battery is either at the end of it's life or has a fault. If the phone is less than 12 months old, it's worth contacting the seller or manufacturer to ask for a replacement
Jun 02, 2009 | Nokia N73 Cellular Phone
nokia mobile phones has maximum charge holding capability.motorola phones consumes more charge if we use mp3 player in it.are you a continuous user of mp3 player then try to decrease it
Jan 15, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
Unable to charge
Same problem here but phone is 14 mo old. Just stopped charging even though it says it is. Got new battery, same thing. Charged battery in different phone and was fine. swapped and it works. so... phone is bad somehow.
Apr 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Charge problems
its because of a faulty charger more than the battery but you could try changing the battery and charger both that should improve the results.
but the piece getting hot might be due to moisture in the piece thus a shorting of some sort, my advice switch to a different piece sell it off, as the v3 circuitry is too complicated for repairs.
Apr 07, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Problem with sliver
sounds like your battery has built a memory and thinks its full try replaceing the battery its a common problem with cell phone dont charge them till they are almost ead and let them drain completely from time to time to avoid this problem
Oct 22, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
155 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
