Question about Zanussi TD4112W Electric Dryer
Hi sometimes it works really well and heats up but other times we have no heat at all. Cyndy
    President:
  • 1,884 Answers
Remove the lint from the lint trap.
Posted on Oct 08, 2009
Spark module wont shut off once it has ignited. Do I need a new one
I would clean the electrodes on the burners really good, sometimes they seem not to sense heat from the burner and will not turn off the ignition system. Other times I fond bad grounds to the cooktop or outlet that can cause the same issue. The electrodes since heat from the burners to shut down the inanition system, also with out a good ground this system is impossible to work correctly.
I hope this helps
Aug 21, 2011 | GE Profile JGP636 Gas Cooktop
I have a whirlpool dryer Model # LEB6000PQ0 It seems to be heating sometimes, but not all the time. Could that be a heating element, or something else? We have to dry a load several times...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 24, 2011 | Whirlpool Dryers
The dryer has does not always heat. You can turn the temp knob to different settings and it will sometimes heat up. It may work on the hottest setting one time then on the med or low setting another...
heatman101
Dec 27, 2010 | Hotpoint Dryers
I have a gas GE dryer DPGT750GCWW ;- it only heats occasionally. Sometimes it will work all day, other times it will heat one load and won't heat up for the next load. The vent has been cleaned...
heatman101
Dec 18, 2010 | GE DBXR463GB Gas Dryer
Blows out cold air at times
In their effort to try to boost the efficiency of the heating units the fan sometimes runs even when the air will feel really cool...
The fan may start up before the heat exchanger is warm and may run after the heat exchanger has cooled off...
Probably nothing wrong... just the way it is...
heatman101
Nov 16, 2010 | Goodman Heating & Cooling
Dryer heats sometime other time wont heat
heatman101
Sep 26, 2010 | Maytag Dryers
Hi. My LG Tromm Dryer DLG3788 warms at times, heats hot others and sometimes won't heat at all. Either way the clothes either don't dry at all or take hours. Any suggestions? Thanks.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Dryers
Hi, Gas dryer does not heat up. It was on Sensor
heatman101
Sep 02, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The burners either don't come on or they have to be turned on HI to come on. When I turn the heat down, sometimes it turns down sometimes it doesn't. Other times I have to push on the burner to make...
Let me get this straight. You want me to pay you to fix this problem.
But, if I already found a solution you want me to tell you what solved it !
You must have a really over sized uterus !!!!!!!!!!!!!!!!!!!!!
Oct 17, 2009 | GE Kitchen Ranges
My iron has a mind of it's own! It will heat for
You need to replace the cord...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 29, 2009 | Rowenta Professional DX8900 Iron
Zanussi TD4112W Electric Dryer Logo
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
