Question about GE Heating & Cooling
Leaking water from the bottom front inside. has never done this and is approx 4 years old
  • petronella08 Oct 10, 2009
    Thanks. I checked and everything seems to be in order. I think the issue is that our freaky Texas weather is freezing the coils when I'm gone. The temperature can drop really quickly when the fronts move in this time of year.
  • 89 Answers
Make sure the unit is tilted to the back and that the drain hole is open.
Posted on Oct 08, 2009
Rusty water dripping on the inside of the door after rinse cycle
Pull the screws out of the door check to see if they are rusted run the machine the outer door panel off should be easier to find the leak
Mar 30, 2014 | KitchenAid Dishwashers
I have a Frigidaire Gallaxy Series top loading washing machine, 4 years old that seems to be leaking from the bottom. Is this something I can fix myself? THANK YOU.
Before you buy a new $100 door gasket, pull out the soap dispenser tray and look inside the washer where it normally sits. If there is significant soap accumulation (even 3/8 inch), the water can become backed up and trickle down the washer front to the door bottom, making it look like a door leak. Fixed mine this way.
Jul 30, 2010 | Washing Machines
Washing machine is leaking water
hi there,
possible leaks can came from mehcanical shaft seal,of agitator shaft and pulley.if worn out
water leak on bottom of machine.
also on water pump inside machine,there is
also mechanical shaft seal within pulley and shaft of impeller blade.worn out also can cause leak at bottom.
maybe on inlet valve of hot and cold water
improper mounting or loosen lock cap on valve
leak can appear.
replacement of shaft seal are lots of work to do in pulling this out,but can be repair depend now on you.how you do it,this should be done by washing machine technician.have a nice day.don;t forget to rate me.thanks a lot
Apr 29, 2009 | Washing Machines
My Admiral Washing Machine (5 years old) is leaking.
Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up,2 screws at the top inside will release the front panel for a better view.
Apr 11, 2009 | Admiral AW22 Top Load Washer
Replaced both elements, both thermostats. What else could it be?
no hidden switches!, did you replace bottom elements? and thermostats? one hint...bottom element heats first, then top...never both at one time.
Mar 24, 2009 | Kitchen Appliances - Others
Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Sep 13, 2007 | Washing Machines
Heating & Cooling Logo
35 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
