Question about Dell Inspiron 9400 Notebook
My Inspiron 9400 started going off and all the lights would go off with the ac power cordYou could wiggle the cord which connects in the back a little and sometimes the green light would come on. The AC adapter is getting hot too. Are the adapters going out or is it the connection on the back of the laptop. How can I fix the back conncection?.
  • Dell Master
  • 32,281 Answers
You could have a power adapter problem, the adapter usually quite warm to touch but not very hot.
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Posted on Oct 08, 2009
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 23, 2011 | Dell Inspiron 2200 Notebook
Dell inspiron 9400 not booting up. no light in display. num keys and caps locks flashing
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jan 28, 2011 | Dell Inspiron 9400 Notebook
I have no power to my Dell Inspiron 9400. I am using a power adaptor whicih I have verified to be workign correctly. I have held the power button down for more than 20 secs, but there is no indication of...
Hello, Rick.
The most common reasons are the battery, power adapter/cord and power jack.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
Hope this helps.
Jan 23, 2011 | Dell Inspiron 9400 Notebook
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Dell inspririon 9400 wont start
(before you do anything remove the battery and th ac plug)remove the memory inside small door on the backside that has a "M" on it now once you remove the memory install the battery, power on if you hear a couple of beep tones you are half way there the motherboard is good so the problem is what you took out so there are two memory slot try them in the A slot one at a time.If the problem is memory replace it.
Good luck
Aug 29, 2009 | Dell Inspiron 9400 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 will not charge - AC adaptor not recognised
Does the laptop power up just no charge the battery? If the laptop does not power on then you may have a bad power supply in the unit. If it does power up than you most likely have a bad battery connector of blown fuse on the motherboard. The flashing of the BIOS is done with a bootable cd or floppy but this will not keep the new battery from charging. The reason Dell states that you need at least 10% battery to flash a BIOS is because if your AC power goes out while you are doing a BIOS upgrade and you don't have battery power the BIOS will be incomplete and your laptop will not boot again without replacing the motherboard.
Jun 17, 2009 | Dell Inspiron E1705 Notebook
Problems with the AC jack on back of Dell Inspiron 6000
there is a small metal inside the dc socket that you need to pull towards the centre so i makes better contact with the charger
Mar 02, 2009 | Dell INSPIRON 6000 CENTRINO...
No power
This might work. Unplug the power cord connected to the back of the PC. Press & hold the start button on the PC case for ten seconds. Reconnect the power cord & try starting the PC. Still no power. Connect the power cord from the PC directly to a wall jack. (No power strips). Still no power? Possible the power supply went bad.
Jan 07, 2008 | Dell Inspiron 3800 Celeron 500MHZ...
Dell Inspiron 9400 Notebook Logo
141 people viewed this question
Alun Cox
