Question about Canon PowerShot A710 IS Digital Camera
When switching on the lens extends fully and then no other functions will work
    Brigadier General:
  • 4,090 Answers
It's possible that the lens is not fully extended, so other functions fail to engage. Please try my fix as follows.
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Canon who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help++++Thanks for using FIXYA
Posted on Oct 08, 2009
E:61:00 error
E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
The simple solution to fix that error message was to the let the lens fully extend and give the lens a good whack. Possibly this error message for this means, that the auto focus motor was past the maximum set point.
This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:
· Turn the camera off
· Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
· Turn the camera on
· Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
· Lift the camera away from the hard surface and notice that the error message is gone.
· Take pictures of your favorite things.
Here is the first alternate method (AVI format)
Here is the second alternate method (AVI format)
Good luck.
May 03, 2011 | Cameras
Hi-- my canon SX110 won't switch on properly. it keeps telling me there's a lens error and to restart. when this has happened in the past, i've just switched it off and then on again and it's worked. not...
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 16, 2009 | Canon PowerShot SX110 IS Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Wobbly lens
Half mm or so movement is normal in fully extended lens. If camera is not giving any error display during function then every thing is just fine in it.
Feb 04, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Canon G9 dropped
I was told it happens when the battery is low
Aug 20, 2008 | Canon PowerShot G9 Digital Camera
Dead
Have read of same problem from numerous users on the internet. One person said this may be caused by a twisted/jammed lens. Apparently the "telescoping" lens mechanism can sometimes jam due to a drop and/or from dirt that gets in the telescoping hardware. The solution that someone gave that I read about involved telling the user to try to gently twist and/or wiggle the extended lens parts counterclockwise to try to "unjam" them. Of course that would also require having fully charged batteries, etc, before you try that, since from my experience, low battery charge results sometimes in the lens not retracting (or extending) properly also. It's worth a try anyway, since apparently your camera isn't functioning properly anyway now with its lens extended. I have a problem w/my On/Off switch not working properly, and in checking w/the Canon USA website, they wanted a minimum of $87 to "start" to attempt to fix it (whatever the problem is), and required that I pay them that much "up-front", and that I agree to whatever it then would cost in toral. I backed out and went and bought some new cameras instead, since I felt that was way too much to invest in my A70, that's already 5 years old now. Good luck w/your extended lens problem.
Jul 25, 2008 | Canon PowerShot A70 Digital Camera
Camera stopped working, lense partially extended
Switch on - lens extends - screen comes up is the normal. Partial extension of lens and the rest does not follow. Why does the lens not complete its function? Probable cause dirt got into the slide mechanism is the simple answer. Very fine mechanism- would not try anything your self. Have you a service facility of watch repair shop near you. Or try the makers web site - they may offer a swap out facility for a modest fee.
May 17, 2007 | Canon PowerShot S60 Digital Camera
W1 lens not extending properly
Lens is damaged. not economic to repair
Dec 12, 2006 | Sony Cyber-Shot DSC-W1 Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
