Question about 3Com OfficeConnect Wireless Router
Sometime internet not working
In our office 35 system is there connected with domin windows 2003 server. Routher we using is 3com, some time in the 3com routher syc line completely off in this time internet is not working after the unplug and plug agin 3com routher internet will work, actually what is this problem and how to solve?.
  • 1 more comment
  • abdul malick malick Oct 08, 2009
    u aksed me to do two solution one solution u given upgrade 3com routher i changed to other routher to linksys also it is giving same problem.and sometime internet is very high speed and sometime it is hanging very very slow.
  • abdul malick malick Oct 12, 2009
    i changed other routher to linksys also , same problem is coming.
  • 4,281 Answers
For That RESET your router all settings to factory defaults.
You can reset it with RESET button .
It is in back panel of router press it for 10 seconds so all settings goes to factory defaults.
Then configure your router again.
Then it works fine sometimes settings are malfunctioned in router so if you reset it it works again fine.
Let me know if you need more assistance.
Thanks.
Posted on Oct 12, 2009
  • 813 Answers
Problem might be due to some electric surge or some electric appliances placed near the router as the problem goes away after a power cycle. Make sure that there is no high voltage current carrying wire placed near the router and place the router on some insulating material. If this also doesnot help, try upgrading the Firmware of the 3 com router and then check.
Posted on Oct 08, 2009
Why does it say communication error when i try to activate microsoft office 2007
This issue may occur if you configure your Internet connection to use a proxy server that requires authentication. In some situations, the Activation Wizard can not connect through the proxy server to an internal Microsoft server and show error message.
Alternatively, this issue may occur if your firewall software is blocking the attempt to connect to the server through your Internet connection.
To resolve this issue configure the firewall software to let the Activation Wizard connect to the Microsoft server or restart the computer in Windows Safe Mode With Networking, and then try to activate the software.
May 25, 2014 | Microsoft Office Word 2003 for PC
Tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
on Mar 22, 2011 | Microsoft Windows Server 2003 Enterprise...
Does microsoft office and student 2010 work in xp
If you would be planning to use microsoft office and student 2010 on xp you have to have SP3 of XP. You may refer to system requirements given below.
Office Home and Student 2010 Component Requirement Computer and processor 500 MHz or faster processor Memory 256 MB RAM; 512 MB recommended for graphics features and certain advanced functionality.1 Hard disk 3.0 GB available disk space Display 1024x576 or higher resolution monitor Operating system
Windows XP (must have SP3) (32-bit), Windows 7, Windows Vista with Service Pack (SP) 1, Windows Server 2003 with SP2 and MSXML 6.0 (32-bit Office only), Windows Server 2008, or later 32- or 64-bit OS. Graphics Graphics hardware acceleration requires a DirectX 9.0c graphics card with 64 MB or more video memory. Additional Requirements Internet Explorer (IE) 6 or later, 32 bit browser only. IE7 or later required to receive broadcast presentations. Internet functionality requires an Internet connection. Multi-Touch features require Windows 7 and a touch enabled device. Certain inking features require Windows XP Tablet PC Edition or later. Speech recognition functionality requires a close-talk microphone and audio output device. Internet Fax not available on Windows Vista Starter, Windows Vista Home Basic, or Windows Vista Home Premium Information Rights Management features require access to a Windows 2003 Server with SP1 or later running Windows Rights Management Services. Certain advanced collaboration functionality requires connectivity to Microsoft SharePoint Foundation 2010 or to Microsoft Office SharePoint 2007. Certain online functionality requires a Windows LiveTM ID. Other Product functionality and graphics may vary based on your system configuration. Some features may require additional or advanced hardware or server connectivity; www.office.com/products.
Mar 18, 2011 | Computers & Internet
Can i use MS Office 2007 on WinXp Home Edition Service Pack 2?
DEAR SIR,
MICROSOFT 2007 WORKS PEACEFULLY ON SERVICE PACK 2,THE ONLY THING IS YOU SHOULD VE ATLEAST 1 GB RAM TO ACCESS IT SMOOTHER AND JUST BEFORE YOU INSTALL M.S 2007,REMOVE THE OLDER VERSION(M.S 2003)FROM UR P.C AND THEN INSTALL IT.......USING M.S 2007 YOU CAN SAVE THE DOCUMENT IN M.S.2003 FORMAT ALSO,AND M.S 2007 HAS VARIOUS OPTIONS WHICH IS HELPFULL TO U THAN M.S 2003...
THANK YOU..TAKE CARE
Oct 12, 2010 | Microsoft Office Professional 2007 Full...
Remote access for 3com firewall network
dial in using the vpn to the windows 2003 server network and call the remote desktopof the server using the netbios name or using the local ip address
Aug 17, 2009 | 3Com OfficeConnect VPN Firewall - Firewall...
When sending e-mail with outlook 2003 some times gets stuck
set your preferences to a lower security level; if this is an office PC, you may have to have IT lower it for you
Apr 17, 2009 | Microsoft Outlook 2003 for PC
I INSTALLED MICROSOFT HOME AND STUDENT 2007 BUT CANNOT OPEN IT
Hello Fawzihadi,
Depending on how much disk space you have left on your hard drive, Microsoft Home and Student requires at least 1.5GB of free space. I've posted the minimum system requirements below, you will need these to run Office Home and Student 2007.
Minimum Requirements: (View on Microsoft Website)
Computer and processor 500 megahertz (MHz) processor or higher1 Memory 256 megabyte (MB) RAM or higher1, 2 Hard disk 1.5 gigabyte (GB); a portion of this disk space will be freed after installation if the original download package is removed from the hard drive. Drive CD-ROM or DVD drive Display 1024x768 or higher resolution monitor Operating system Microsoft Windows XP with Service Pack (SP) 2, Windows Server 2003 with SP1, or later operating system3 Other Certain inking features require running Microsoft Windows XP Tablet PC Edition or later. Speech recognition functionality requires a close-talk microphone and audio output device. Information Rights Management features require access to a Windows 2003 Server with SP1 or later running Windows Rights Management Services.
Connectivity to Microsoft Windows Server 2003 with SP1 or later running Microsoft Windows SharePoint Services is required for certain advanced collaboration functionality. PowerPoint Slide Library requires Office SharePoint Server 2007.
Some features require Microsoft Windows Desktop Search 3.0, Microsoft Windows Media Player 9.0, Microsoft DirectX 9.0b, Microsoft Active Sync 4.1, microphone1, audio output device, video recording device (such as a webcam), TWAIN-compatible digital camera or scanner, Windows Mobile 2003 powered Smartphone or Windows Mobile 5 powered Smartphone or Pocket PC, or a router that supports Universal Plug and Play (UPnP). Sharing notebooks requires users to be on the same network.
Internet Explorer 6.0 or later, 32 bit browser only. Internet functionality requires Internet access (fees may apply). Additional Actual requirements and product functionality may vary based on your system configuration and operating system.
Mar 19, 2009 | Microsoft Office Professional 2007 Full...
How to make a pcmcia 3Com 3crwe737a working on XP ?
Hope this is what you are looking for...
http://www.3com.com/products/en_US/result.jsp?selected=5&sort=effdt&order=desc&sku=3CRWE737A
Have a nice day.
Jun 24, 2008 | Microsoft Office Outlook 2003 for PC
User login problem in win2003SBS domain
ReInstall domin controller or configure domin setting
May 26, 2008 | Microsoft Windows Server Standard 2003 for...
3com router dmz doesnt allow to ssh to the asa
undo the dmz and forward the ports 22 for ssh and any other services you need to the cisco. Ok dmz is not good... 3com calls port forwarders virtual servers just add what you need there... hope that helps.
Mar 20, 2008 | 3Com OfficeConnect Router
3Com OfficeConnect Wireless Router Logo
74 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
