Question about JVC AV-27050 TV
Thin horizontal line across blank screen
Jvc av 27050 television, thin horizontal line across middle of blank screen. used to correct by wiggling coax feed, now it is worse (wiggle won't fix). removed back, removed a part with the coax connection plus a male RCA and a female RCA. i think this part has a cold solder, can't open to fix. part labeled 0409 811a, can't find this part number listed at partstore.com what is it called so i can look it up by name?
3 Suggested Answers
SOURCE: JVC AV-27730: horizontal bright line across screen in the
if you havent fixed your problem yet, i had the same problem twice. It turned out to be the vertical hold. i have had the tv for a long time and had three problems. like i said twice the vertical hold and now i have no picture with a blinking light. i may give up on it and get rid of it
Posted on Nov 14, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: The tv has a black screen with a white horizontal
The trouble is not in your tuner, it's in the set's vertical output circuit. A very common source of trouble is bad solder connections to the vertical output integrated circuit. When you wiggled the antenna connection before, it flexed the circuit board enough to get the connections working, but now it's not. A few minutes with a soldering iron very likely would get the picture back, although it's possible the IC itself has gone bad.
I believe that on the chassis in this set, the vertical output IC is an LA7832, mounted on a heatsink near the rear of the circuit board. I think it's marked IC421 on the board. If you or someone you know is comfortable with electronic soldering, you can try resoldering the connections.
Posted on Jan 31, 2011
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Shows gray screen on all channels
between image controls, (contrast-brightness-colour), Check the "colour" setting. should be near the middle of it's way.
if an automatic scan was performed before the event, please start it again, but assure proper country selection when asked (or better, check if there is a country selection menu and have it set to your country BEFORE starting the autoscan.
Aug 31, 2009 | JVC AV-27050 TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
Blank screen with a line across the middle
thats the VERTICAL OUTPUT IC that went bad , needs to be replaced . hope this helps
Apr 30, 2008 | Jensen 5" Color TV 5 in. Portable...
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Thin Horizontal line through tv blank screen.
Replaced vertical IC ( la78041 ??>.. Or La78040 ). Look for born resistor beside IC. Replaced capacitor 100uf 35V too!!! Good luck !!
Nov 08, 2007 | Insignia NS- 27" TV27 TV
JVC AV-27790 - single horizontal line
Since Intermitant always inspect the vert ckt for bad solder connections. If not replace the output IC they're cheap and most likely the problem If you still have lines on the top or bottom I would replace all of the electrolytic capacitors in the vert ckt also. Without much test equipment rebuilding the whole little ckt is the best way to go.
Apr 24, 2007 | JVC AV-27790 27" TV
JVC AV-27050 TV Logo
95 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
