Question about Hotpoint Dryers
Wd420 does not dry washing. - Hotpoint Dryers
  • 74 Answers
Heat element bad
Posted on Oct 08, 2009
    Scholar:
  • 121 Answers
Your dryer exhaust may be full of lint. You may have a defective thermostat. Sounds like you need to call a repair specialist if cleaning out the lint from the exhaust ductwork doesn't help.
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
I have a Hotpoint Aquarius WD420, the dryer isn't drying its making all the right sounds its spining but the washing is just not drying. Please Help!!!
sounds like the termo stat packed in if you take the top off you will see it. It will have 2 wire 1 on each side it will be round common fault their are around £15 good luck hope this helps
Jan 20, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
I have a Hotpoint Aquarius WD420 washer/dryer that is not heating the washing water, yet does heat when in drying mode. Does the machine use the same heating element for washing and drying, or are there...
There is a seperate element for the water heater. so likely to be a faulty heater or thermistor which is fastened toi the element
You really need a test meter to determine which part is faulty.
Dec 27, 2010 | Hotpoint Washing Machines
MY HOTPOINT W/DRYER WD420
yes test the thermostat for continnuity with a multimeter , about 25 bucks for a new 1 ,can order from Repairclinic.com
Feb 06, 2010 | Washing Machines
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Feb 05, 2010 | Hotpoint Aquarius WD640 Front Load...
WD420, drying high heat, time saver and ON/OFF buttons are flashing, no function out of machine at all
this usually means that the main pcb has a corrupted eprom or eprom memory has been wiped... you either need a new pcb with eprom or a new board pre-programmed.
hotpoints terms for error
Setup error: check eeprom
F09
Flash
OFF
OFF
Flash
OFF
Dec 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
No heat
Check on the back of the drum for a thermal fuse or relay. Common fault on tubledryers is no power to heating coils becuse of blown fuse or most likely the relay to heating coils is dirty. have to be cleaned about every 2/3 years depending on use.
Aug 09, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpiont aquarius wd420
not left on long enough or half blocked water outlet
Nov 15, 2007 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
43 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
