Question about NEC ND-6750A DVD RW Dual Layer Burner
Rewrittable drive reads diks as wrong types
For example when i come to burning a audio disk,i make the list and all then get asked for blank cd so pop 1 in,it reads it then a message pops up asking for a blank cd-r disk which is what the disk is....Is the driver shot?any help at all would be much appreciated.Many Thanks
  • 2,427 Answers
Yep Drive is shot
I'd recommended you try upgrading the firmware or using a different media before buying a new one
Posted on Dec 30, 2007
Why does my burner heeps ejecting blank discs
You must be using the wrong type of disk. Make sure if you are trying to burn a CD that you have a blank CD in the drive. If you are trying to burn a DVD make sure it's a blank DVD in the drive.
Jun 30, 2012 | HP SR5710F PC Desktop
It is running very slow . It can't read a little bit old cd\ dvd. When a cd/dvd is inserted system has encounted a problem amd hang up for several minutes .............. and it can't burn disc...
This sounds like a simple problem to fix. You need to get a cd/dvd cleaner disk and place it in the drive. Allow the disk to perform as indicated by the audio instructions included on the disk. All modern lens cleaning disks have the audio instructions that play as the disk is in the machine, so that the customer knows what to do, and in what order to do it in.
After running the disk, get a NEW blank cd, and try to burn some files onto it. If it works right, then that was all that was wrong, if not, then you have corrupted firmware, which is also a relatively easy procedure to fix. Just go to the drive manufacturers website and download the latest firmware fore your drive.
Jan 22, 2011 | Office Equipment & Supplies
I have never burned a CD. I have need of burning two tonight. What do I do?
are you burning a cd or dvd? burning a cd is pretty easy...windows will do most of the work for you. put a blank cd in your cd rom/ dvd burner drive. it will ask you what you want to do with the blank cd...vista usually asks you to format the disk...select ok.....a blank box will pop up....drag and drop your files to be burned into the blank box.....once you are done putting your media onto the disc....eject the disk...before the drive opens a box at the bottom of the screen says that the disc is being prepared for use on other computers. when it ejects, it should be done....you can try to put it back in to the cd drive and see if your data/media files are on the disc. ......now burning a dvd is alot more complicated....do you have software for burning dvd media? if you do, they have help me files and tutorials........some more good advice....youtube also shows good tutorial vids on burning. just type in "burn a cd or dvd".
Oct 12, 2010 | Computers & Internet
Does not recognize disk
Either:
* the disk you're inserting is not "empty" -- try it on a different computer;
* you should try a different manufacturer of "blank" disks;
* you need to upgrade the "firmware" inside your CD-writer, to recognize more brands of "blank" media;
* the CD-reader is malfunctioning -- when you "cancel" the burn-attempt, and insert a commercially-produced program CD or commercially-produced audio CD, can those disks be properly read?
* you have two CD/DVD devices in your computer, and you're inserting the "blank" disk into the "wrong" device.
Jul 18, 2010 | Yamaha CRW 2200E CD-RW Burner
My CD-ROM drives (Internal and External) won't read blank disks
i wonder wat r u searching in blank disk. its blank thats why ur drives r not reading
Jan 06, 2010 | Compaq iPAQ Legacy-Light PC Desktop
I have been attempting to burn a cd from my itunes library, it keeps giving me an error 2630. Yes I am using a new blank cd.
What type of CD media does your burner support? CD+R CD-R, CD-RW.
A few suggestions:
CD-RW or re-writables do not support audio burning to CD format.
Are songs being burned as a data disc(unplayable files) or CD audio?
Have you exceeded the 700 to 800 MB range of data that a CD can hold?
Try dropping a couple of songs off the list and see what happens.
Try rebooting the computer and try burning again.
Down load a free version of Nero software and try to burn the CD from there.
Oct 13, 2009 | HP HewlettPackard Pavilion ZE5400 series:...
It can't read or burn any data on any empty disks (CD-Rom/DVD)! but it can read any other written disks like: programs , Movies , audio disks , data disks just when I put a blank or Empty disk it seems...
Some CD burners are either "+" or "-" or both "+ -".
That said you will have to check what type of burner you have. Example, you cannot stick a "+" blank cd into a "-" burner, and visa versa.
However, if your cd burner can read and burn both types, you should be okay.
Sep 25, 2009 | LG SecurDisc 8x External Double-Layer DVD...
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
DVD drive doesn't read suddenly...?
IF YOU MADE ANY MOVEMENT OF YOUR COMPUTER YOU MAY HAVE DAMAGED THE READ LED ON YOUR DVD, IF THIS IS THE ONLY DRIVE ON YOUR COMPUTER COSIDER AN ADDITIONAL DRIVE
Feb 21, 2008 | Computers & Internet
NEC ND-6750A DVD RW Dual Layer Burner Logo
106 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
